Westr 10 Posted June 7, 2020 Hi I have noticed there is a small crack in my cylinder head and I want to replace it. Only thing is I’ve noticed my engine in my Corrado is a AAA code which if I’m right is a Golf VR6 engine. Would a Corrado VR6 cylinder head mate on top of this ok? Can anyone advise me regards. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 7, 2020 Pretty sure you can, maybe a phone call to stealth racing to confirm. However you should be able to pick a AAA head easier and cheaper. It may also be running with the obd2 wiring, inlet manifold and throttle body. Quote Share this post Link to post Share on other sites
Westr 10 Posted June 7, 2020 Ok thanks I shall give them a call and have a look around. Thanks. 19 minutes ago, 1xshaunx1 said: Pretty sure you can, maybe a phone call to stealth racing to confirm. However you should be able to pick a AAA head easier and cheaper. It may also be running with the obd2 wiring, inlet manifold and throttle body Quote Share this post Link to post Share on other sites
Westr 10 Posted June 7, 2020 23 minutes ago, 1xshaunx1 said: Pretty sure you can, maybe a phone call to stealth racing to confirm. However you should be able to pick a AAA head easier and cheaper. It may also be running with the obd2 wiring, inlet manifold and throttle body. I take it there would be no performance gain from getting a Corrado cylinder head then? Quote Share this post Link to post Share on other sites
seanl82 23 Posted June 7, 2020 Heads are exactly the same. Only difference is bore size (obviously), inlet manifold, and throttle body if OBD2 from a MK3. The performance gains are mostly in the inlet manifold and management. Quote Share this post Link to post Share on other sites
1xshaunx1 27 Posted June 7, 2020 And you can get a nice new throttle body for the AAA/Obd2 if you need one. Quote Share this post Link to post Share on other sites
