captquo 0 Posted October 25, 2020 Hello. My first post. I have a Corrado interior and the driver's seat belt stalk needs replacing. I have a replacement (535 857 756 A 01C : Bouton poussoir - press button buckle with warning contact - Gurtschloss) from https://www.mecatechnic.com/en-GB/vw_classic_parts.asp How do you get the old one off? Thanks Quote Share this post Link to post Share on other sites
fendervg 33 Posted October 25, 2020 Is that for a European or NA spec car? As far as I know only US models would have had a warning contact, and also motorised seatbelts. The buckles are usually anchored into the chassis near the centre tunnel using a captive nut and a large bolt - best way to get at it would be to remove the seat in question (2 securing parts and slides off the rails) as it won't slide far enough forward or back to give good access. Quote Share this post Link to post Share on other sites
captquo 0 Posted October 25, 2020 Hi. European and the stalk is attached to the seat itself. Can't upload my images though :-( Quote Share this post Link to post Share on other sites
fendervg 33 Posted October 25, 2020 (edited) Looks fairly straightforward - large bolt to the rear of the inside seat frame. Might be hard to get to with the seat in place. Edited October 25, 2020 by fendervg Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 25, 2020 (edited) I've just found these photos online that may be of help, but it's pretty much what Fendervg has mentioned above, your best bet is to remove the seat, rather then trying to do it in situ. First photo shows the seat completely removed, and highlighted in yellow writing, regarding the anchor bolt to remove. Second photo is from VW Etka look at item 5, that I think is the bracket that the seat belt stalk is bolted to. Hope this helps Si Edited October 25, 2020 by vw rule Quote Share this post Link to post Share on other sites
fendervg 33 Posted October 25, 2020 That's a great photo of it Si. Shows it very clearly - I was originally getting confused with the rears - of course the fronts need to slide, and have the seat belt rail for the bottom as well. Should help sort it out for the OP. Quote Share this post Link to post Share on other sites
