Cressa 45 Posted May 25, 2021 I've been watching tooo much you tube and decided I want a play at using electrolysis to do some rust removal. Has anyone done this? And had better success using a certain product. . .salt, baking powder, soda Crystal's. Just seen a good Anode of an opened up tin can around the object so may try that. Or i am talkimg total rubbish and ignore this thread 🤣🤣🤪 Share this post Link to post Share on other sites
Dox 26 Posted May 25, 2021 (edited) On 5/25/2021 at 7:34 PM, Cressa said: I've been watching tooo much you tube and decided I want a play at using electrolysis to do some rust removal. Has anyone done this? And had better success using a certain product. . .salt, baking powder, soda Crystal's. Just seen a good Anode of an opened up tin can around the object so may try that. Or i am talkimg total rubbish and ignore this thread 🤣🤣🤪 I played with this last year in lockdown, I did a Corrado rear axle in a wheelie bin using two old front struts for the rust to deposit onto. Two days then flipped the axle over for another two days. The rust goes flakey and is easily removed with a wire brush. i used washing soda from home bargains 90p per packet. My neighbour also did it on his T25 van bits cant find it online on HBs website, but they do sell it, B and M also my set up https://www.bmstores.co.uk/products/dri-pak-soda-crystals-500g-349612 Edited May 25, 2021 by Dox Share this post Link to post Share on other sites
Cressa 45 Posted May 26, 2021 Cheers Dox, I thought you had done some. Going to try with a rusty old brake disc first. Full marks for use of your wheelie bin though 🤣🤣 great idea Have you done any of the oxide coating of parts also? Share this post Link to post Share on other sites
Dox 26 Posted May 26, 2021 On 5/26/2021 at 8:52 AM, Cressa said: Cheers Dox, I thought you had done some. Going to try with a rusty old brake disc first. Full marks for use of your wheelie bin though 🤣🤣 great idea Have you done any of the oxide coating of parts also? I stopped because recycling was piling up lol - handily wheelie bins are marked up in litres helping the mixing of he soda. I recommend it though. The residue on the struts is like egg shell and also cleans off easily, I used a battery connected to the charger at all times which seems to help. Share this post Link to post Share on other sites
