fla 9 Posted July 12, 2021 Just wondering how people have routed their HT leads with a schrick. Mine sit under the manifold on each side but very close to the engine block. So they're not insulated from the heat from the engine. Any other solutions in use? Pics would be great. thanks Hasan Quote Share this post Link to post Share on other sites
fendervg 33 Posted July 13, 2021 Lots of pics here if you scroll down a bit: https://www.google.com/search?q=schrick+vgi+corrado&tbm=isch&ved=2ahUKEwjGgtG7iODxAhXWSEEAHRfxDOQQ2-cCegQIABAA&oq=schrick+vgi+corrado&gs_lcp=CgNpbWcQAzoECAAQHlDhMliaTGDQTWgAcAB4AIABYYgBzgiSAQIxNZgBAKABAaoBC2d3cy13aXotaW1nwAEB&sclient=img&ei=gontYMa5AdaRhbIPl-KzoA4&bih=581&biw=1356&client=firefox-b-d Looks like most seem to run them underneath, front and back rows, and then out to the side. Not sure if you would need slightly shorter than standard to keep it all neat? This is why I'd prefer a VSR over a Shrick if my dreams ever came true - kind of a style over substance thing, as I do know the Shrick delivers a more bang for your buck 😉 Quote Share this post Link to post Share on other sites
fla 9 Posted February 18, 2022 Just an update here (6 months later!) and as Fender suggested the standard solution is best. I have ended up using a spare side trim piece and routed the leads through that as per a normal manifold setup. Much better than using the previous three-cable plastic spacers. The whole bay needs a proper clean and tidy up so this will form part of the "resto" work Quote Share this post Link to post Share on other sites
