mooG60 11 Posted August 30, 2021 I am experiencing rubber banding while cruising at low revs. It's more severe in second than higher gears and seems to be getting worse with use. There is no loss of power or running issues when I open it up though. I know it's impossible to diagnose online , but I just wondered if anyone had experienced similar and can suggest a few areas I could check over before opening the wallet again. Thanks chaps. Quote Share this post Link to post Share on other sites
Dox 22 Posted August 30, 2021 Do you mean surging? Quote Share this post Link to post Share on other sites
mooG60 11 Posted August 30, 2021 The revs don't surge if that's what you mean? Not sure if rubber banding is the correct term, I can feel the engine rocking back and forth as it's happening. Quote Share this post Link to post Share on other sites
Dox 22 Posted August 31, 2021 Its probably the hardest thing to diagnose if its only when being driven and under load? Ignition Fuel Engine / gearbox mounts Try and watch the tacho when the issue is happening to see if it drops to zero. Checking battery connection, main engine earth connections for cleanliness and security. Make sure the fuel and ecu relays are pushed all the way in / pins are clean. Wiggle the ignition key to try and replicate the fault Quote Share this post Link to post Share on other sites
Cressa 44 Posted August 31, 2021 11 hours ago, mooG60 said: The revs don't surge if that's what you mean? Not sure if rubber banding is the correct term, I can feel the engine rocking back and forth as it's happening. I've never heard of rubber banding 😁, but if you think the engine is moving, check it parked up. Rev the car with the bonnet open and watch what it does 👍 Quote Share this post Link to post Share on other sites
mooG60 11 Posted August 31, 2021 Sorry chaps, I don't really know how to describe it any better. Thanks for the tips though, I will get it serviced and re-tuned and see how it is after that. Quote Share this post Link to post Share on other sites
