bigpants baby 0 Posted August 7, 2004 hi id like to do the above mod to a k reg corrado Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 7, 2004 You'll need the following:- 1994 on upper chain cover (to house the cam sensor) Cam position sensor Coilpack and corresponding Low tension wiring loom. HT leads for coilpack Cam trigger wheel on rear cam 1994 ECU and corresponding Cam sensor wiring loom. It's not worth it. Quote Share this post Link to post Share on other sites
VR6 0 Posted August 7, 2004 What would the benefit be? Other than a more expensive fix when it undoubtedly goes wrong?! :D Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 7, 2004 There is no benefit. The cam position sensor and coilpack do exactly what the Dizzy, hall sender and HT coil do! Quote Share this post Link to post Share on other sites
bigpants baby 0 Posted August 7, 2004 i have everything bar the coilpack ecu,no all i was thinking i have just bought a k reg c vr6 with a dizzy,thinking it would be more desirable with coilpack? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 7, 2004 It's a lot of work mate. You won't notice any performance increase. It's cheaper to just keep replacing caps and rotor arms every now and then. Quote Share this post Link to post Share on other sites
Henny 0 Posted August 8, 2004 Personally, I'd always plump for a rotor arm and dizzy cap over a coil pack every time... You just need to look at the problems that VAG are having at the moment with Audi TTs and VAG 20VTs loosing coil packs alllllllllllllllllllllllll over the place to realise that this is a technology which has not yet been perfected.... :| Gimme something mechanical with 100 years of experience over something electronic with less than 20 years anyday... ;) 8) (and this is coming from someone with an electronic, electrical, computer and mechanical engineering degree! ;) :lol: ) Leave it how VW intended and you'll do MUCH better... ;) :D Quote Share this post Link to post Share on other sites
vr6storm 0 Posted August 8, 2004 i have everything bar the coilpack ecu,no all i was thinking i have just bought a k reg c vr6 with a dizzy,thinking it would be more desirable with coilpack?................IMO it would only really be "desirable" if you were looking at 2 K/L-reg C VR's and one of them had the coil-pack while the other had the dizzy......it just means the coil-packed equipped one is newer.......AFAIK there is no difference power or torque wise so no real gain is had..............afterall its not so much age which is affecting C values now........more like condition Quote Share this post Link to post Share on other sites
