Check vcds first,vac leak,bad idle valve,bad plug lead...
Check you have the correct plug leads to the coil pack
UK VR6s are OBD1, this precedes OBD2 which scanners are designed to be used on, hence there use is quite limited.
are you distributer or coil pack?
You need a plug lead removal tool to get the leads off the plugs, yanking on them will damage them. Some cars still have these clipped to the bonnet stay, otherwise it’s eBay I’m afraid.
https://ebay.us/m/dJ1JU5
Edited by Dox
Fault codes can still be read with or without a scan tool,best use a plug lead removal tool as they do break easily,check all the vac and intake pipes post maf as they can be brittle with age
Idle is really controlled by the ECU along with inputs from all the other sensors - MAF, crank, lambda, cam and ISV and throttle position, a vac leak would usually cause a high idle I think. Even though it's OBD1, you will still get lots of useful info, both in terms of fault codes, if any, and real time stats on what the ECU is seeing. You can also initiate an ECU reset procedure that puts it back into initial learning mode using the software, so I would recommend getting it scanned. Checking all leads and the distributor (92 should be dizzy rather than coil pacl) and the coil would also be a good start.
