G60Dan 0 Posted August 16, 2004 Any better than the std corrado g60 equipment? or is money better spent on a rallye one? Cheers Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 also what's the difference in them if the car it originally came from had air con? Quote Share this post Link to post Share on other sites
Henny 0 Posted August 16, 2004 The Golf G60 intercooler is what I've got on my car, it's sodding enormous and VERY efficient! :) 8) definately worth the money they go for (should be around £400 -> £500 with all pipes and 180degree charger outlet) To be honest, it's difficult to get worse than the original Corrado intercooler 'cos it was soooooo small and just got heatsoaked sooo quickly... The aircon Golf's version is about double the size of the standard Corrado intercooler and sits on top of the engine just perfectly where it can get sod all air flow and get nicely heated by the engine... avoid as much as you can! ;) Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 Thanks Henny, all the answers as usual! :wink: Do you happen to have a few pic's of yours mate? Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 Also is yours the one off of the a/c model? Quote Share this post Link to post Share on other sites
Jim 2 Posted August 16, 2004 The Golf G60 i/c is also fitted to my car... I don't have any pics to hand because it sits in front of the radiator and under the slam panel so basically you can't see it unless you remove the grille (which I could try and do later if I remeber for you!) but its pretty similarly sized to the radiator. You'll notice its there - its a great mod :) Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 does this look like yours mate? http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting Think it could be advertised wrong going by your description Do you reckon one of these might do the trick? :) http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... otohosting Quote Share this post Link to post Share on other sites
Pau1 0 Posted August 16, 2004 Dan, if its an IC from a Golf with air con it might be the smaller version which sits in the engine bay beside the battery not a front mounted one. If its cheap thats probably the reason. Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 Dan, if its an IC from a Golf with air con it might be the smaller version which sits in the engine bay beside the battery not a front mounted one. If its cheap thats probably the reason. it's looking that way :roll: :( But would it be better than the std corrado one? Quote Share this post Link to post Share on other sites
Pau1 0 Posted August 16, 2004 You could always try plumbing the Golf one in aswell as your Corrado one. Or just get a Merc Sprinter IC. Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 don't suppose you know anyone/anywhere selling a Merc Sprinter i/c Quote Share this post Link to post Share on other sites
Jim 2 Posted August 16, 2004 You could try dropping Darren / g-man a PM - he might have a Golf G60 intercooler in his garage for sale, or might know of someone he could get one from? Quote Share this post Link to post Share on other sites
Pau1 0 Posted August 16, 2004 No not at the momment Dan. Just try your comercial breakers yards found in the back of Auto Trader etc. Good Luck. Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 You could try dropping Darren / g-man a PM - he might have a Golf G60 intercooler in his garage for sale, or might know of someone he could get one from? I haven't got £400 just lying about unfortunately - Chargers getting serviced/upgraded at the end of the month so looking for a cheaper option right now :wink: Cheers paul, will have a look what's the exact model it comes off of? Or will everywhere know what I'm on about if I just ask for a merc sprinter intercooler? And how much should I be expecting to pay do you think? Quote Share this post Link to post Share on other sites
Pau1 0 Posted August 16, 2004 what's the exact model it comes off of? Or will everywhere know what I'm on about if I just ask for a merc sprinter intercooler? They should know what your on about. Any TD Merc Sprinter Van should be the same. Quote Share this post Link to post Share on other sites
Henny 0 Posted August 16, 2004 as stated above, the airconditioned golfs had a smaller intercooler which would get as near as damn it NO airflow through it if used on a Corrado... They weren't much good on the golf, so they'd be bloody awful on a Corrado! The NON air-con Golf G60 intercooler is full width... here's a pic of mine just as I was fitting it, you can see the radiator behind it is small in comparison! :| 8) An important thing to remember when selecting an intercooler is the pipework... if the pipes are in the wrong places then you'll either make it far too much work for the intercooler to be viable, or you'll need so much pipework with so many twists and turns that the flow through the cooler will be pants and you may as well just fart into the throttle instead of having the supercharger! :lol: Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 :shock: Christ! How does the size of that compare to the rallye one? What's the going rate for one? Do you have any pic's of the pipe work? Was it much work? Quote Share this post Link to post Share on other sites
Henny 0 Posted August 16, 2004 the rallye one is identical in core size, it's only the inlet which is different (closest in that pic)... 8) The Golf one just bolts straight into the Corrado with a very few minor alterations to allow clearance for the headlamps... 8) After I'd worked out which bits needed modding on the front of the intercooler and attacked it with my anglegrinder it took about an hour to fit it including all of the pipework and everything... 8) Quote Share this post Link to post Share on other sites
Jim 2 Posted August 16, 2004 As Henny said in his first post Dan, about £400/£500 should find you a complete Golf G60 intercooler kit :) Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 16, 2004 As Henny said in his first post Dan, about £400/£500 should find you a complete Golf G60 intercooler kit :) DOH! oh well, plan "B" :roll: Quote Share this post Link to post Share on other sites
Henny 0 Posted August 16, 2004 If you get a second hand intercooler, make sure that the rubber pipes are in excellent condition... :| I'm in the process of replacing mine after I've burst one (don't ask! :roll: ) VAG prices for rubber pipes are truely horrible... :cry: Supercharger outlet to Intercooler £105.57 Intercooler to Plastic pipe £57.21 Pipe to Throttle body £75.18 Gasket for Supercharger outlet £22.77 All + VAT! :crazyeyes: :mad: You need all 3 of those rubber pipes, the 180degree supercharger outlet pipe (with support bracket) plastic pipe (which houses the CO pot) and the actual intercooler itself to make up the full kit... 8) Just don't ask VAG how much they want for a new intercooler unless you're off you head on something strong! :crazyeyes: :x Quote Share this post Link to post Share on other sites
G60Dan 0 Posted August 19, 2004 If you get a second hand intercooler, make sure that the rubber pipes are in excellent condition... :| I'm in the process of replacing mine after I've burst one (don't ask! :roll: ) VAG prices for rubber pipes are truely horrible... :cry: Supercharger outlet to Intercooler £105.57 Intercooler to Plastic pipe £57.21 Pipe to Throttle body £75.18 Gasket for Supercharger outlet £22.77 All + VAT! :crazyeyes: :mad: You need all 3 of those rubber pipes, the 180degree supercharger outlet pipe (with support bracket) plastic pipe (which houses the CO pot) and the actual intercooler itself to make up the full kit... 8) Just don't ask VAG how much they want for a new intercooler unless you're off you head on something strong! :crazyeyes: :x surely silicones would be cheaper!! :shock: Quote Share this post Link to post Share on other sites
RACK 0 Posted August 19, 2004 They are, but you have to wait 6-8weeks to get them Quote Share this post Link to post Share on other sites
Henny 0 Posted August 19, 2004 You can get silicone ones from Germany and avoid Samco and their stupid waiting list times entirely! :D :lol: 8) (mine should be here within the next 24 hours! :D ) Even VW stated 5 to 10 working days to get the pipes over here... :roll: Quote Share this post Link to post Share on other sites
RACK 0 Posted August 19, 2004 Henny, I've just seen your new pipes on the Dubforce thread. They look well smart! I've still got a set of Samco coolant hoses to go on mine. Will I ever get round to getting things done?? :roll: Quote Share this post Link to post Share on other sites
