whiteee
Rear heated window...
Right... another niggly problem...
The switch on dash board doesnt light up wen depressed?!?! And the window doesnt clear... is this a problem with switch or window (Im guessing at least the switch...)
also to add to the problem... i think the hatch mite hav been replaced somewen in the cars life cos the lock doesnt work with the key but all electrics (Central locking, lights, wiper etc) work apart from heated screen???
I assume you've checked the fuse - a dumb question I know, but since the heated screen itself and the lamp in the switch are powered via the same fuse it has to be the first question.
Yeah... had a few niggly electric problems (starting mainly...) so checked all of fuses at the wknd... mite change it jus to sure...
