Rossco
FAO all you etka users, Update:- onto question 2 please
Could you look up this part number and give m ethe description, ive got etka but it wont let me input part no's
Part no: 357 906 363
Cheers guys
Ross
In etka it lists it as a a fuek pump retardation relay whatever that means???? But looking at the diagram and location it doesn't make sense as it says it locates in relay position 13, which is the abs pump relay according to the bentley manual. I personally think it is probably the fuel pump after run relay. Where on your relay panel is it located is it above the main 2 rows of relays up on the top of the fuse box??? If it is then I would put my money on it being the after run relay!
Hope this helps!
Yep its above the 2 main rows, it actually clips onto the top of the fusebox so i just clipped it off and its still attached to the loom at the moment
Supercharged wrote:
Something to do with the rev limiter??
i always thought the rev limiter just cut the spark?
Yeah, that makes more sense.. last thoing you want to do is run a FI engine lean! :?
You would be right nigel :D
It's more likely to be the fuel pump after run relay!!! IMHO
Some rev limiters just cut the spark, typicaly every other firing for a soft cut and every spark for a hard cut.
Some also cut the fuel by not turning the injectors on so you dont get unburnt fuel in the exhaust which wouldn't do the cat any good.
