16,478 -
Days Won
Supercharged last won the day on June 27 2014
Supercharged had the most liked content!
2 NeutralAbout Supercharged
Legacy Moderator
- Birthday 04/24/1980
Turnip Land
IT Contractor
Supercharged changed their profile photo
Supercharged started following If you are insured through Adrian Flux check your policy, Error messages when following links, Handbrake light intermittently going on and off and and 6 others
Supercharged replied to _Matt_'s topic in Site Comments and Questions
Hi all, I'm aware of the issues as is Andi but as Jim says aboove, Toby (the owner) is the only one that currently has the access to fix - I've dropped him a message and we'll do everything we can to safeguard the information and repair the forum. -
Just over 14 years and we have an answer :-)
Only took 11 years for the OP to get a reply!!
Supercharged replied to KARMANN's topic in ICE 'n' Secure
Low brake fluid... if it appears low and the pads are not worn / due for a change then suspect one of the clutch components is leaking. Look for signs of brake fluid on top of the gearbox (under the clutch slave) -
Same... must be a similar age to us and he had a young family from looking at his FB profile :-(
When was it last MOT'd? Does it feel like something is hitting? Maybe worth a trip to KwikFit etc in case a bush has collapsed etc.
Do you have the recall bypass valves still fitted?
Hi all - some sad news and apologies if I've missed a post about it. I just saw on Facebook that it looks like Bally sadly passed away yesterday... Just wondered if anyone knows the circumstances? I never really knew him but met him a number of times at shows and he was one of the original members on this forum and still had his C from what I can see...
http://www.hotukdeals.com/deals/bosch-s4-battery-063-4-year-guarantee-34-64-eurocarparts-with-code-2487649 Keep a look out for the discount codes and also look on Carparts4less - paid £33 for one not so long ago...
After market upgraded CV inner and outer joint and drive shaft kits.
Supercharged replied to EJ Taylor's topic in Drivetrain
Gkn -
Assume it wasn't a genuine tank?? unfortunately many of us have had issues with pattern ones, they usually work for a few months though before they fail, not a day :-)
You can buy it as a kit that contains the oil filter.
They'll probably do a better price as well for 4...
The spoiler module is fairly close to where the headlight loom runs... I would check this in case the Earth on that loom has burnt out - this can happen with headlight switch failure and many of us have fitted a fuse on this wire to prevent this happening. Usually it's connecting the speed sensor wire on the stereo that causes the spoiler not to work!
Supercharged replied to marks2's topic in Insurance
FCA are aware and just found this - http://www.fscs.org.uk/news/2016/july/update-for-customers-of-enterprise-insurance-company-plc/
