gor123don
13 -
0 NeutralAbout gor123don
- Birthday 10/11/1939
Surrey
Cars and motorcycles
C.Eng. Retired
gor123don started following Possible ignition switch ?, Tweeter speaker, Fog light without lens anyone? Gaiter and tunnel Karmann and and 3 others
Required drivers side dash tweeter speaker to replace blown unit.
gor123don replied to Kempy's topic in Parts for Sale
Hi Would like to purchase gear surround and gaitor for £15.00 plus p&p if ok please let me know your paypal address Regards - gor123don -
Car now gone see link in 1st post for new thread
gor123don replied to P3rks's topic in Cars for Breaking
Hi Would like to purchase gear gaitor surround, gaitor and gear knob providing the gaitor is in good condition and the surround is grey. If they are please let me know your paypal address.I assume the price includes postage? Regards-gor123don -
Corrado 2.0 16v LC6P - Updated with pics
gor123don replied to diarmaid16's topic in Cars for Breaking
Hi. If not sold would like to purchase the "Grey gear gaitor and surround" Let me know your paypal address if I am lucky. Regards-gor123don -
If not sold happy to give you £45 inc p&p via paypal Regards-gor123don
Just purchased new ignition swich from VW dealers in Epsom. Had one in stock Pt. No. 6N0905865 cost £26.89 (£22.41 + £4.48 vat) and comes with a 3 year gaurantee so the salesman said.
Thanks to all of you who responded to my engine problem.Now to update you on my experiences in getting the engine running again. You may recall at the beginning of September that my Corrado (1992 2ltr 16v 118500miles) engine just cutout when stopping at a crossroads and would not fire or startup and as a consequence I had to be towed home. When home I contacted a mobile mechanic who came to the house and the first thing he does is turn on the ignition and try to start the car and of course it did not fire or start.He then :- 1) Took out the four plugs and checked they were all sparking,said there was petrol in the bores (after shining a light down them) and then replaced the plugs. 2) Took out one injector turned engine over on starter motor and demonstrated normal spray pattern-replaced injector. 3) Took off cam belt cover and checked timing -all correct and replaced cover. 4) Disconnected air duct from metering unit at manifold and squirted "quick start" directly into engine air manifold and then tried to start engine without success.(It did not fire at all) 5) Checked all fuses and pushed all relays and tried to start the engine again -no luck. 6) Finally said he did not know what the problem was .Paid him £30 and he left. One week later I found another mechanic who said he had worked on Corrado's when new at a Vag dealer.He arrived and the first thing does is try and start the engine without success. Then he says I will try one thing before trying to read any fault codes! Where upon he unclips the metering/air filter housing and lifts up sufficiently to spray "Quick Start" into the air filter. Leaving the filter not fully rehoused he turns the engine over and it fires first time and continued to idle smoothly. He then pushed the filter assembly fully home and does up the clips.He switched off the engine and restarted it five times on each occasion starting first time. He took the car away to use for a week and check to see if he could find any sensor faults.He brought the car back last week could not find any faults whatsoever but had fitted a new fuel pump relay.He remembered that when the cars were new that they had problems with the relay but he could not say that this was the reason for my engine cutting out. Cost £123 including £18 for new relay. The car seems to be running better than ever. What do you guys think will happen again? (Remember all the sensors and relays are 18 years old - I have owned the car for 11years) or is there some other reason?
The engine is not even trying to start. It just died when stopping at cross roads. Someone mention to me that it maybe failure of the transfere fuel pump in the petrol tank - is this possible? The 9A 2ltr 16valve.
1) If the ISV unit has failed will the engine still start and run? 2) When the ignition is switched on (prior to the starter being operated) does the ISV "buzz" and if so is it loud enough to hear inside by the driver? 3) If not the ISV what else can "buzz" in the engine compartment when the ignition is switched on and can be heard inside until the starter is operated? Reason for asking is I broke down two weeks ago when engine just stopped-had to be towed home.Have checked fuel pump,injectors,plugs are sparking all ok but engine will not fire up. Used to get "buzzing noise" when ignition turned on and engine started but this dose not occur now and engine will not start. Any advice will be greatly appreciated.
Hi. I have had a second hand passenger door fitted to replace the original kicked in by vandals.The mechanic who did the job handed the protector strip to me for fitting.As a consequence could someone please advise on the product (double sided tape,Adhesive etc) used to secure the protector strip to the door.Your help will be most appreciated.
Door handle repair kit..........THEY ARE NOW AVAILABLE
gor123don replied to daves16v's topic in Suppliers Forum
I would like to purchase drivers door repair kit. Please advise cost and payment arrangements. I hope Paypal is accptable. Your early reply would be greatly appreciated. Regards gor123don
