daves16v
Door handle repair kit..........THEY ARE NOW AVAILABLE
Pmd you Dave. I hope these are available as I cannot source replacements for my 93 VR6. Just got her all up and running again with a full engine swap, now the door handles are preventing me from driving it haha.
Hi, just wondered if these were still available? Need one for my VR6
Yes still available, will PM you.
33 minutes ago, dap1275 said:
Hi Dave, can I order a pair for my `92 G60 please?
Yeah sure, I'll drop you a PM.
Dave
Pair arrived as promised and I fitted the passenger side yesterday, was a bugger to get the pin out but the instructions supplied were spot on. Thanks, Dave!
I found the easiest way was to use a small punch or screwdriver to hammer it out towards the back of the handle, to break off the metal covering, and then once that goes, push it back out towards the front.
The real tricky bit for me was to re-assemble the spring onto the lock tabs - if you can avoid taking this bit off, it's much easier.
Yes this is in the install guide.
Ha ha Daves16v - that’s exactly where I got it! Worked a treat. I did try to drill one out before, but it’s quite tricky and easy to damage the rest of the mechanism. A reverse tap might work with the spring tension off once it is in.
1 hour ago, Pete S said:
Hi Dave,
if these are still available can I please order a pair for my 1990 1.8 16v 👍
Regards Pete
PM sent.
