Tekara
Fuel Filler Earthing Help
Hi All
While i was unblocking the waste pipe in the rubber seal around the fuel filler, i thought it might be a good idea to clean out the road gunk from behind. As seems to be common while gently pull the gunk away i found the earth cable for the fuel filler. Its rusted off, and now as there is no road gunk to hold it in place im left with a loose wire.
Whats the best way to secure this back in place ?
I just cleaned mine up by cutting the copper earth wire back to a clean bit and soldered it to the metal filler pipe (outside). Very fiddly - I'm not sure if its a good join but I had forgotten about it until you mentioned it Tekara, and I havnt blown up at a filling station yet!
What does that cable actually earth? Does it prevent stray static sparks igniting the fuel vapours or something?
I assume so... Its just safety as your filling up I suppose...
How many of us fill up with our mobiles switched on in our pockets...?
How many of you saw Brainiac? (waits for inevitable jokes about shell suits :lol: )
i saw that, i dont do shell suits leave that to the townies
And Supercharged :lol: ... I'm amazed he hasn't blown himself up yet.
