mwcarrera
Automatic Spoiler
Advice please on the non-operation of the rear spoiler? Works manually but does not rise at speed. Is there a speed sensor/relay or the likes which can be changed? thanks,Martin
id like to hear any suggestions on this too :)
just bought the car (92,g60) and it only works with the button,but goes down its self :?
neil.
You chaps tried hitting the search? Spoiler has come up for discussion (and diagnosis!) quite a few times ;)
if the control unit has gone would it still work with the switch though?
sounds more like the speed sensor
*sigh* If you plug the speed sendor into the wrong bit of your head unit, you toast it.
This not only kills the fancy volume uppy-downy with speed control on your stereo, but as it's the same unit that controls the spoiler, that too.
The spoiler control unit is separate, so it still works on the swtich, just not automatically.
Take the spoiler control module out and make sure it's 2 relays haven't fried. The module is clipped to the dash under the driver's side air vent.
i tried the search but it dosnt seem to bring anything up for me? :?
could someone explain this a little more?
does the stereo volume adjust with speed or something? :?
where on your stereo is this blue wire supposed to go?
sorry for the newbie type questions,but im new to all this!
neil. :)
