ashvdub
quick tyre profile question
185/55 is the lower profile, as the 55 is a percentage of the tread width...
Though 195/50 will be the same as 185/55 and cheaper I suspect...
Yup, they tyre's profile is expressed as a percentage of the tread width, so if you have two tyres with a 55-profile, but one is narrower tread width, then the profile will also be smaller...
I'm sure I've mentioned this before somewhere...!
Nothing to do with stretch at all!
The sidewall profile of a 185/55 tyre will be 55% of 185mm, which equals 101.75mm.
The sidewall profile of a 195/55 tyre will be 55% of 195mm, which equals 107.25mm.
Therefore, the 185/55 has a lower profile sidewall - simple!
ta, never realised it was a percentage, just thought they were random numbers :roll:
will I be able to stretch 185/55/15's on 7" easy enough? Got some in my shed, so it'll save buying new ones seeing's as i'm searchin for new wheels anyway.
Yeah, they will go on ok, would go for 195/50's myself tho, will give you a bit of extra grip on the road, only 10mm but every bit helps
Can I tag another question onto this 'quick .. .. question' thread??
I've always put on 205/50/15 and have never had anyone advise me differently. Could I put on 195/55/15 or 185/55/15 and what difference would they make?
And if I can, how come? Don't they have to fit the width of the wheel or is a range of 20 negligible!
Butterfly, The over all diameter off your wheels would be different which would mean your speedo would be out, otherwise you can put what you like on - i wouldn't go any bigger though
