weedwhacker 0 Posted July 10, 2005 hiya guys, this is my first post on here... so ill say hi at the same time as asking a question. i have a 16v 1.8 rado.. it done 173k now and all is good, apart from when it revs over about 4500rpms in any gear it sort of misses and looses power, not the best for whipping past trucks on back lanes.. i havent done anything to it as yet, ie plugs leads ect.... it dies have some "hot wires" ht leads which i have a feeling are cheap shitty ones.. been told that the best ones are vag std leads.. i have had a few golfs and sciroccos in my time but this is the first rado ive ever had. is it just gonna be a matter of a good service and clean down, or could it be something a little more costly.. cool nice one fellas tony... :shock: Quote Share this post Link to post Share on other sites
chrishill 0 Posted July 11, 2005 hello mate, welcome to the forum! If you've not changed your leads yet then I'd do that along with the dizzy cap and rotor arm, something I firmly believe all new 16v owners should do as a matter of course as it only costs £70 tops can make a massive difference. I'd get it serviced (or service it yourself?) and see how its running after that. At least that way you'll have ruled out servicable parts and the common leads/dizzy/arm problems. Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 11, 2005 yeah..i'd agree with chris. gotta be worth giving it a little service...your problem does sound typical of a sh1te lead or something.... Quote Share this post Link to post Share on other sites
chrishill 0 Posted July 11, 2005 any whining from the fuel pump? just thinking it could be that on its way out and giving up the ghost when its being pushed? Quote Share this post Link to post Share on other sites
weedwhacker 0 Posted July 11, 2005 no whining at all, strnge realy as she is good all the way up to and sometimes just over 4k then it sort of dies and splutters and shakes the car.. ony gets to me as im now driving like a grandad on a sundy afternoon.. got blown away by a max power saxo yesterday on the way home, pity as i couldnt give anything back for fear of being laffed at when the car started spluttering. never mind.. roll on pay day. Quote Share this post Link to post Share on other sites
chubbybrown 0 Posted July 11, 2005 Sounds like fuel starvation. changed the dizzy cap and rotor arm myself,works out about £9 Quote Share this post Link to post Share on other sites
weedwhacker 0 Posted July 11, 2005 so you think the fuel pump is failing under load then... or could it just be an in line fule filter clogged up. reason im askin is at the min money is realy tight until i get paid, and i dont want to fork out for leads and plugs and stuff now when i can get away with doing it later. im waiting for big stuff untill either edition 38 or vw action later in the year realy, can get bits a bit cheaper there. Quote Share this post Link to post Share on other sites
chrishill 0 Posted July 11, 2005 could be the filter, the only real way to know is to have a look and change it. The only really expensive parts of what's been suggested so far are the leads and the fuel pump, try the little things first and see what happens. As chubby brown said, the dizzy cap and rotor arm are cheap as chips, so you might as well do them, and have beans for tea :) Quote Share this post Link to post Share on other sites
Walesy 0 Posted July 11, 2005 and the fuel filter too...its about £8 and easy to change.... Quote Share this post Link to post Share on other sites
corradophil 3 Posted July 11, 2005 If you have access to a timing light, a free, quick thing to check is the ignition timing, otherwise I'd go with what everyone else said. Also what about the injectors?? These are not cheap at around £120, but they are an easy D.I.Y installation and at 140K miles made a noticable performance increase on my valver. Quote Share this post Link to post Share on other sites
rs200f40 0 Posted July 11, 2005 Change the spark plugs first if you haven't already done so, my 16V Golf always did the same when the plugs got too worn. Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted July 11, 2005 If you figure out what it is, pm Phil K and let him know, as he's having a very similar problem on his at the mo, and the garage it's at don't seem to be able to trace the cause... Quote Share this post Link to post Share on other sites
weedwhacker 0 Posted July 20, 2005 ok will do.. it a strange one it comes and goes at arount 4500rpm. also its now started doing it only in 5th gear at about 2500rpm. roll on pay day... im just limping it to and from work now... i hope it makes it for the rest of the mth. Quote Share this post Link to post Share on other sites
