Ice White Socks 0 Posted July 23, 2003 Hello- just been searching on the internet for a workshop manual to help me out with little bits like this- bit gutted to find out the only one available is a reprint of the proper VW technical manual for about 100 quid :( :( . Anyway- the clutch on my VR bites a little too high up for my liking and was going to adjust it this weekend.On my old Corsa it was a one minute job; why do I get the feeling its going to be a bit more complicated on the VR :roll: Quote Share this post Link to post Share on other sites
dubster82 0 Posted July 23, 2003 I dont think you can, its hydraulic and adjusts itself... :? Quote Share this post Link to post Share on other sites
macca 0 Posted July 23, 2003 Have been checking the US e-bay for the Bentley manual, some going for £50ish, nearly half UK money. Quote Share this post Link to post Share on other sites
Andi 2,147,483,647 Posted July 23, 2003 I bought mine from Amazon US - with cross-atlantic shipping, tax and everything, ended up at £70. A lot cheaper than Amazon UK. Not sure what the prices are now though... might be worth a look? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 24, 2003 The Clutch is non adjustable :? No info on adjustment :( Cheers James Quote Share this post Link to post Share on other sites
Supercharged 2 Posted July 24, 2003 Yes, you want to compare if the clutch feels different to another VR6, if so you may have a leak in the hydrolic system Quote Share this post Link to post Share on other sites
woody 0 Posted July 24, 2003 I paid £62 including postage from Amazon Quote Share this post Link to post Share on other sites
Joe M 0 Posted July 24, 2003 Could try bleeding the system. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 25, 2003 Joe M said: Could try bleeding the system. It bites to high up ,bleeding it would not sort it ,if it had air in the hydrolic it would bite to low down near the floor.... James Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted July 27, 2003 Cheers james- appreciate your post with the diagram. Have had more trouble cos someone crashed into the C on the Arnison roundabout on Sat morning.. Its gonna take at least two weeks to get it straightened out. Saw your car on Friday night (green with white bumber). If u drive from the stonebridge pub up to Nevilles cross bank, there is a set of terrace houses on your right. The corrado is parked on a private drive (not mine) just after the terrace. Have a look at the damage if u r drivin past and let me know what you think. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 27, 2003 Gona have a look mate... C ya later James Quote Share this post Link to post Share on other sites
Ice White Socks 0 Posted July 27, 2003 How can you tell if you need a new clutch then? Its just that I though It would need replacing about now (75K). Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 27, 2003 Drive down the road about 30mph in top gear,dip the clutch,give it a good rev ,release the clutch and it should bite straight away to bring revs to normal...but if it continues to rev high the clutch is on way out :( Also clutch judder is also a sign thats its poor... :( Cheers James Quote Share this post Link to post Share on other sites
stevemac 0 Posted July 27, 2003 Ice White Socks said: How can you tell if you need a new clutch then? Its just that I though It would need replacing about now (75K). If yer gears aint crunchin and yer clutch aint slippin - leave it well alone. Quote Share this post Link to post Share on other sites
vr6storm 0 Posted July 27, 2003 CorradoVR6-n.o.s said: Drive down the road about 30mph in top gear,dip the clutch,give it a good rev ,release the clutch and it should bite straight away to bring revs to normal...but if it continues to rev high the clutch is on way out :( Also clutch judder is also a sign thats its poor... :( Cheers James also another way to tell if the clutch is going is.........park,put handbrake on,select 2nd gear and raise the clutch pedal.....if its good it should stall straight away if its bad then it should still keep on running but won't move at all.....remember not to use the throttle at all Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 27, 2003 vr6storm said: CorradoVR6-n.o.s said: Drive down the road about 30mph in top gear,dip the clutch,give it a good rev ,release the clutch and it should bite straight away to bring revs to normal...but if it continues to rev high the clutch is on way out :( Also clutch judder is also a sign thats its poor... :( Cheers James also another way to tell if the clutch is going is.........park,put handbrake on,select 2nd gear and raise the clutch pedal.....if its good it should stall straight away if its bad then it should still keep on running but won't move at all.....remember not to use the throttle at all It must be well f**ked to do that.. :lol: James Quote Share this post Link to post Share on other sites
vr6storm 0 Posted July 27, 2003 CorradoVR6-n.o.s said: vr6storm said: \ said: Drive down the road about 30mph in top gear,dip the clutch,give it a good rev ,release the clutch and it should bite straight away to bring revs to normal...but if it continues to rev high the clutch is on way out :( Also clutch judder is also a sign thats its poor... :( Cheers James also another way to tell if the clutch is going is.........park,put handbrake on,select 2nd gear and raise the clutch pedal.....if its good it should stall straight away if its bad then it should still keep on running but won't move at all.....remember not to use the throttle at all It must be well f**ked to do that.. :lol: James[/quote:4f5ad] very true :lol: :lol: Quote Share this post Link to post Share on other sites
Scott 0 Posted July 28, 2003 I'd be surprised if only done 75k and needs new clutch - am on 104k miles now and clutch still feels light and smooth (touches wood) :D Quote Share this post Link to post Share on other sites
stormseeker 0 Posted July 28, 2003 Scott said: I'd be surprised if only done 75k and needs new clutch - am on 104k miles now and clutch still feels light and smooth (touches wood) :D PANIC - remember what happened the last time you said something like that .... :D I'd buy a replacement clutch in now if I were you :wink: :lol: Quote Share this post Link to post Share on other sites
Scott 0 Posted July 28, 2003 Hence - the touch wood PS. VR is running like a dream (goes off into the woods in search of trees) Quote Share this post Link to post Share on other sites
stormseeker 0 Posted July 28, 2003 When it comes to the Corrado, there isn't enough wood in the world....... :? :D Quote Share this post Link to post Share on other sites
Scott 0 Posted July 28, 2003 True for some maybe - but I have had Corrados for 5yrs now and they have never given me any real grief..... Ive put a total of 80k miles on them in 5yrs and only had to replace wear and tear items and general servicing - Im not complaining at all 8) :) Quote Share this post Link to post Share on other sites
