rmn
Peloquin Limo Diff's???
I think Stealth charge £550 plus vat for a standard rebuild - I doubt fitting that would be much ontop tho but best check with Vince...
The above is just to do the box, if you want to drive in/out then add the price of a clutch change ontop of that... not cheap!
I paid (delivered) for the Diff £420
for the rebuild of the Box £195
1 x 2nd gear Synchro £42
1 x seal set £17
2 x pinion bearings £34
and to fit it £100
total £808
You dont need to I suppose if you know theres plenty of life in the clutch but I changed that at the time aswell as final drive ratio but thats personel preference.
That's a damn good price for a rebuild John!
In all I paid £1350 fitted inc VAT at Stealth for a full rebuild, VAG clutch, quaife, 3.68 crown wheel and shaft etc. I had all of the Syncs and bearings done though, which aren't cheap. 2nd gear synch is made up of 3 seperate rings, the others are one piece. It's well over a £150 just for all the syncs!
Worth it though as it's essentially a new box as the gears them selves and obviously the casing never really wear out.......unless you strip the teeth with too much torque :-)
Yeah I didnt need all the Syncs just second and 2 pinion bearings!
I just left them to it as thats all they do so maybe thats why the price is cheaper as they are a one trick ponnie!
Oh and Happy New Year Peeps :drinking:
looks like about 875 dollars rec retail on their website
A friend of mine is thinking about importing them. As soon as i know more i'll post up details.
email the lad who runs the scirocco.com
he will do you a good deal
I can mail him and see what about a group buy?
yeah i think a few people are interested by the look of this thread
does anyone else wamt one of these if we can get 5 or 10 members we should get an ok discount i would of thought?
