rixy 0 Posted October 7, 2005 Just noticed i got locking wheel nuts on me new raddo, and i didnt get a key to get em off? How am i gonna get em off to change the wheels etc? Can any tire place do it for a fee maybe? Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted October 7, 2005 What type of locking nuts are they? You can often get a master key or alternatively depending on the type of nut you might be able to hammer a slightly smaller impact socket on to them! Quote Share this post Link to post Share on other sites
ben16v 0 Posted October 7, 2005 put a pic up mate (if your gonna get rid sharpish) that`ll get a few suggestions Quote Share this post Link to post Share on other sites
KADVR6 0 Posted October 7, 2005 i used a small screwdriver, tapped it into the locking bolt and just kept on tapping it round until it came out. :wink: Quote Share this post Link to post Share on other sites
.Rich. 0 Posted October 7, 2005 i also have this problem so would be interested in the answer, just been hoping that i dont get a flat else im fekced :E Quote Share this post Link to post Share on other sites
Phil K 0 Posted October 7, 2005 Can't you contact the last owner to see if they still have the key? Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 7, 2005 Are they the OE fit trilocks? Try the dealer, they might have, or can get a key. Hammering a socket over trilocks is tricky as they have a hardened steel outer ring, but you can try it. I had the same problem with mine, but one of them rounded off and it had to be drilled out.....which destroyed one drill and 3 bits in the process. Good luck! Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted October 7, 2005 if you take it to a wheel specialist you shouldnt have a problem with most types. i know the new mc gard ones are tricky though. Quote Share this post Link to post Share on other sites
BigTartanJudge 0 Posted October 8, 2005 You can buy tools at most good motor factors or Halfords or DIY stores that have a head full of many spring-loaded metal pins that automatically form around the shape of the head of the bolt you need to remove and then you just use a wheelbrace on the tool to remove the bolt. Hope this helps and good luck Quote Share this post Link to post Share on other sites
h100vw 0 Posted October 8, 2005 Are they the OE fit trilocks? Try the dealer, they might have, or can get a key. Hammering a socket over trilocks is tricky as they have a hardened steel outer ring, but you can try it. Good luck! I got 4 of these out in ten minutes. PM me if you want to know how. That 'hardened steel' ring ain't that hard IMO. :wink: Gavin Quote Share this post Link to post Share on other sites
edd 0 Posted October 10, 2005 take a trip down the local scrappy chuck one of the chaps there a fiver and give him ten minutes - works every time. Just remember to take a new sets of locking nuts with you. Quote Share this post Link to post Share on other sites
Walesy 0 Posted October 10, 2005 i know the new mc gard ones are tricky though. my mate lost his years ago and we had to take a digital pic (( luckily my dad had a digi-cam when they were first out ! )) of the bolt and send it to a place in germany, they then sent him a new one....i cant remember how much it cost him..but it wasnt too expensive. Quote Share this post Link to post Share on other sites
blackcat 0 Posted October 10, 2005 What is the point of locking wheel nuts when they are so easy to get off without the key? :? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted October 10, 2005 What is the point of locking wheel nuts when they are so easy to get off without the key? :? because it takes time to take them off and in most cases you need to make a lot of noise i.e big hammer Quote Share this post Link to post Share on other sites
rixy 0 Posted October 10, 2005 been to see me mate at a vw garage, and they ar only the standard tri locks anyway, so no prblems there, worrying about nothing again, ha ha, cheers anyway! Quote Share this post Link to post Share on other sites
