H8RRA
Info needed on potential Golf VR6 runabout
What d'you reckkon to this as a runabout to get the 'C' off the road?
the £1600 one
click me!
Are 95 golfs highlines or obd2?
Any other advice on the golfs?
Edit: Link shortened ;) - dinkus
supercharge it? ;)
the only thing I've been told to look for on mk3's is rust hiding under the plastic arch trims, otherwise I'm sure you know what you're looking for in a 2nd hand car!
any advice anyone???????
Make your links shorter ;)
:roll:
i didn't make it i only copied it :wink:
mk's do rust
they rust in the tailgate lots!
they also rust under the plastic sill trimas and arch trims too
doors sag a lot as the pins ware and the sunroof switch breaks too.
as for the engine, i think in 1995 it should be obd2, but not 100% on that, didnt kev get some obd2 stuff, he might be the best man to ask
he obd2'd the 'C' - thats what i need to know really - whether its obd2 as a switch-around could be on the cards if i got it
I've a feeling all the late mk3 vr's are odb2 paul, i'm positive I've heard they changed over at the same time as the corrado vr.
I think kev wanted the highline stuff because it'd be 'last off the line' in terms of vr's and odb2.
OBD2 came out in 1997, so you're looking for P and R plate Golfs. I think there may even be a few S plate ones around as that's the change over year to the MK4. The Highline was OBD1 and OBD2 because of the 96/97 change over.
My stuff came from a 97 Highline if it helps. I'd visit the car to make sure it is OBD2 as some sellers probably won't know the difference!
As a run around, you'll get bored sick of it after a week as they are nothing like as good as a Corrado to drive.....but it's good for nicking parts from.
VAG-COM is VAG-COM, there is no 'MK4' version. It covers all VAG cars that use the standard VAG protocols, so G60/16V ABS ECU/VR6 onwards basically.
i thought it wouldn't take long for the wire to drop in :)
this one's an m plate so i doubt theres much worth knicking -
hmm, what winter hack shall i have- tdi golf, audi cab or vr golf :scratch:
AARRRGGHHH!!!!!!
Dilema - veedubs - vw specialists up here - reckon all coilpack vr6 golfs are obd2
this car has a coilpack but is an M plate and i thought obd2 was on P & R only - or is that just highline????
HELP!!!!!! If this is an obd2 i really fancy it for running around and then switching stuff over.
whats the best golf forum to get definitive info???
AARRRGGHHH!!!!!!
Coilpacks were introduced in early 94 to both the Golf and Corrado, but neither were OBD2 at that point. OBD2 came about because of America's 'clean air' act which stipulated that all cars from 1996 had to have OBD2, so there's no way an M reg Golf will be OBD2....but the easy way to tell is to look for a stepper motor on the throttle and deletion of the idle valve. Some Ns might be OBD2 but defo R and P reg. The run out VRs weren't highlines, so a plain Vanilla VR on an R or S is the last of the last and the best ones as they also got the simplex chains and solid tensioners etc.
