pacificshack 0 Posted December 1, 2005 Hi I'm sure this ones been done before. Anyone here know how to change the green LED's to red to get a more updated feel? Thanks Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted December 1, 2005 It has been done to death, but I don't think there's any one definitive thread on exactly what to do so... Dash switches - prise them apart carefully, remove the green plastic filter and replace with red cellophane OR remove the filter and replace the illumination bulb with a 12V red 3mm LED Window/sunroof switches - carefully prise apart, remove the green LEDs and replace with std voltage red 3mm LEDs Heater panel - afaik, no1 has yet converted an early spec to red... Cigarette lighter - scrapyard, get the lighter from a 95-on Passat, or a 90-on SEAT. Instrument cluster - remove from car and dismantle. replace green overhead strips with red cellophane, remove displays from circuit board and replace green filters with red or blue cellophane depending on preference. you can also reverse the polarising filter (red on black instead of black on red) but you'll need to wire up the backlight bulbs to come on with the ignition, not the lights. Think that just about covers it! :lol: Quote Share this post Link to post Share on other sites
g60greeny 0 Posted December 1, 2005 http://cgi.ebay.co.uk/CORRADO-LED-SPEED ... dZViewItem comes with fittin instructions or ya can do what i did which is a cheaper option an just change the filters Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted December 1, 2005 gradeAfailure said: Instrument cluster - remove from car and dismantle. replace green overhead strips with red cellophane, remove displays from circuit board and replace green filters with red or blue cellophane depending on preference. you can also reverse the polarising filter (red on black instead of black on red) but you'll need to wire up the backlight bulbs to come on with the ignition, not the lights. To reverse the polarising lense youll need a stanley knife blade and a hair dryer to heat up it up while you slice the film off. fairly easy. Also you need to get hold of some quite dark red film (ive still not found one that im happy with) to light and it just looks tacky. Also some led replacements for the crappy bulbs. Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted December 1, 2005 The blue illumination looks a bit dark.... ok if you're going between 60 and 100 though.... Quote Share this post Link to post Share on other sites
g60greeny 0 Posted December 1, 2005 think the blue ones just a crap pic :) Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted December 1, 2005 is that bthe standard blubs behind a blue filter or they LEDs? Quote Share this post Link to post Share on other sites
gradeAfailure 0 Posted December 1, 2005 I found it's better to change the filters as LEDs don't really give a good spread of light - more a direct beam... [/2p] Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted December 1, 2005 sand the leds with fine sand paper and leave the orginal white filter in as well as the colour that works quite well Quote Share this post Link to post Share on other sites
pacificshack 0 Posted December 1, 2005 Great, thanks for this. Will this work I'm mine though, my dash is the old style 1990, so only one LED set. (MFA computer) Quote Share this post Link to post Share on other sites
catch_twotwo 0 Posted December 1, 2005 I'm thinking of doing the whole dash and all (that I can) switches.... So if anybody has a spare instrument panel let me know as I'm bound to need one in a few weeks when I've burnt this one out ;) Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 1, 2005 Anyone know the actual size of the bulbs behind the clocks? Im sure I can find those LEDs cheaper. Quote Share this post Link to post Share on other sites
DaveVR6 0 Posted December 2, 2005 no, but id have some off you if you can! Quote Share this post Link to post Share on other sites
davidwort 0 Posted December 2, 2005 gradeAfailure said: Heater panel - afaik, no1 has yet converted an early spec to red... Done the heater panel, it's a fiddle as the green filter is paint and overlaid with black and white for the pictures of the seats, screen etc... you need to very gently rub down the plastic film with everything printed on it with wet and dry, taking care not to rub off the bottom layer of white and black or you end up with nothing but a clear bit of plastic film!, this also involves carefully breaking apart the two plastic halves of the panel. I used a red plastic filter to get the new colour. cruddy picture attached, but you get the idea, looks much better in real life, honest :) David. Quote Share this post Link to post Share on other sites
g60greeny 0 Posted December 2, 2005 DaveVR6 said: is that bthe standard blubs behind a blue filter or they LEDs? blue leds Quote Share this post Link to post Share on other sites
Stan 24v 0 Posted December 3, 2005 Anyone know the size? Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted April 19, 2006 David Wort - have you done all your interior switches? Any advice? Cheers Quote Share this post Link to post Share on other sites
dinkus 10 Posted April 19, 2006 The How-to guide on CCC is of great use ;) Quote Share this post Link to post Share on other sites
Bojmobile 0 Posted April 19, 2006 Cheers Dinkus - that looks like it'll be a good help. :thumb right: Quote Share this post Link to post Share on other sites
JMC 0 Posted April 19, 2006 I've also done the early style heater controls, by printing out a new design on acetate and fitting that in instead of the green one. At the same time I fitted a couple of extra bulbs as well making it all a bit brighter. Also done all the interior switches (thanks for your help GradeA) and fitted the DDI dials... Quote Share this post Link to post Share on other sites
ben16v 0 Posted April 19, 2006 JMC, liking the guage pod idea. did you get it finished and was there any cutting of the plastic involved?? pics? got my gauges and senders but am a bit reluctant to start cutting away cheers ben Quote Share this post Link to post Share on other sites
JMC 0 Posted April 19, 2006 ben16v said: JMC, liking the guage pod idea. did you get it finished and was there any cutting of the plastic involved?? pics? got my gauges and senders but am a bit reluctant to start cutting away cheers ben Thanks ben16v, yes it is finished (see attached for a rather shaky picture). There was a small amount of cutting needed at the bottom of the slot where the ash tray used to live. With hindsight I would probably have removed a little bit of plastic from the top of the slot rather than the bottom to improve access to CD's below. Maybe next time :D :D Quote Share this post Link to post Share on other sites
ben16v 0 Posted April 20, 2006 you got a day pic by any chance? thanks Quote Share this post Link to post Share on other sites
davidwort 0 Posted April 20, 2006 Bojmobile said: David Wort - have you done all your interior switches? Any advice? Cheers the dash switches use filters and bulbs, I simply used some filters from some old audi switches to do these some needed a bit of super-glue to hold the filters in place, the roof and window switches need to have a red LED soldered in place of the green ones, everything can be prised apart and reassembled fairly easily, just take a bit of care. David. Quote Share this post Link to post Share on other sites
JMC 0 Posted April 20, 2006 ben16v said: you got a day pic by any chance? thanks Here you go... Quote Share this post Link to post Share on other sites
