Kevin Bacon 5 Posted March 16, 2006 My car had an uprated loom on it when I bought it but I've never been happy with the way the loom connects to the lights - with spade connectors. It's a real pain if the lamps have to come out as the loom is pretty short aswell, meaning the spades have to be pulled. So to finish the loom off and make it easier and quicker to remove the lights, I purchased the following from my local Audi stealer.... 2 x 357 941 165 (water proof plugs) - £4.64 each 4 x 000 979 407 - 6mm preterminated leads - £2 ish each You basically take 2 leads per plug, slot the spades into each plug hole and then snip the leads in half to give you your 4 connections, and then cut the spades off the uprated loom and solder the wires together to give you a proper OE fit and finish. Just thought this might help anyone that has the same frustration! I've been having iffy sidelight bulb connections recently and taking the lights out (easiest way to change bulbs) was a pain. Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted March 16, 2006 Ive done this to my VR aswell when i made up a loom, OEM is this best way by far,ive also uprated the wires inside the headlight for Full Power! Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 16, 2006 good mod on a mod kev, probably be looking to do this as i`ve always been a bit wary of the spade situation! Quote Share this post Link to post Share on other sites
mr.ots 10 Posted March 16, 2006 Already uprated my loom and been thinking about this mod for some time Kev. Part no's are usefull, thanks for the info. :) Quote Share this post Link to post Share on other sites
joebloggsVR69 0 Posted March 17, 2006 I bought the same parts a couple of weeks ago 8) Can't stand using spades either Quote Share this post Link to post Share on other sites
gaz the geezer 0 Posted March 17, 2006 ........just off to get the bits .........cheers kev :thumbleft: Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 17, 2006 Good mod Kev - I shall be mostly ordering those parts soon :) Quote Share this post Link to post Share on other sites
bcstudent 0 Posted March 17, 2006 I paid £2 total for the same connectors chopped off a scrap Corrado. They do seem to be few and far between at the scrap yards though. Just need to find a similarly elegant solution for connecting to the original plugs now... Quote Share this post Link to post Share on other sites
Geo 0 Posted March 17, 2006 Cool! I got the plugs a while back but couldn't source the correct onnectors to fit in the plug anywhere. Didn't realise they were available from the dealer. Those part numbers will come in very useful, thanks Kev! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted March 17, 2006 You can actually buy bare connectors from some place on the net, but I thought it was easier to just buy the cables instead ;-) Quote Share this post Link to post Share on other sites
24V Renshaw 0 Posted March 17, 2006 I paid £2 total for the same connectors chopped off a scrap Corrado. They do seem to be few and far between at the scrap yards though. Just need to find a similarly elegant solution for connecting to the original plugs now... Solder them on then shrink sleeve them in black, then wrap in proper loom tape. Can't get better than that. jay Quote Share this post Link to post Share on other sites
Bally 0 Posted March 17, 2006 nice one Kev, Ive taken my loom out as the mainbeam on the stalks wouldnt work for MOT... a job for the wkend.... Quote Share this post Link to post Share on other sites
Geo 0 Posted March 17, 2006 I just had a look at the 89 passat I bought for parts last week and it appears to have the same connectors as the corrado on the headlights. Could be another option for getting complete plugs as they would be more plentiful in scrapyards than corrados. Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 17, 2006 They're Hella lights, so I guess they'll be the same connectors on quite a few different cars (not just VWs either) Edit: According to ETKA, the plugs were used on... 86-91 Golfs 88-91 Passats 92-93 Passats 90-93 Passats 88-91 Jettas So there ya go... Quote Share this post Link to post Share on other sites
h100vw 0 Posted March 17, 2006 They're Hella lights, so I guess they'll be the same connectors on quite a few different cars (not just VWs either) Edit: According to ETKA, the plugs were used on... 86-91 Golfs Rallye 88-91 Passatsall passats 92-93 Passatsall passats 90-93 Passatsall passats 88-91 Jettascan't think of a jetta with the right lights unless they did them with Rallye lights in some markets or maybe those nasty US spec ones?? So there ya go... Gavin Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 20, 2006 Apparently it's "88-91 Jetta syn./Golf Var.syn." Whatever that means? :? Quote Share this post Link to post Share on other sites
NormanCoal 0 Posted March 20, 2006 syn. - syncro var. varient, or estate Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 20, 2006 Ahh clever :) Quote Share this post Link to post Share on other sites
bcstudent 0 Posted March 20, 2006 I paid £2 total for the same connectors chopped off a scrap Corrado. They do seem to be few and far between at the scrap yards though. Just need to find a similarly elegant solution for connecting to the original plugs now... Solder them on then shrink sleeve them in black, then wrap in proper loom tape. Can't get better than that. jay No, I mean connecting the other end of the loom to the original headlamp connectors without modifying the original wiring. Quote Share this post Link to post Share on other sites
STORM 2 0 Posted March 20, 2006 I paid £2 total for the same connectors chopped off a scrap Corrado. They do seem to be few and far between at the scrap yards though. Just need to find a similarly elegant solution for connecting to the original plugs now... Solder them on then shrink sleeve them in black, then wrap in proper loom tape. Can't get better than that. jay No, I mean connecting the other end of the loom to the original headlamp connectors without modifying the original wiring. An important question seeing as this is where most of the corrosion occurs on the blade terminals because they are exposed (well on mine anyway). I suppose hacking the male connector off a damaged light is an option but they would be hard to come by...but if this system applies to passats and jettas they would be a bit more plentiful Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 20, 2006 I think you'll struggle to find male connectors because they're all part of the light housing. But then again - why on earth would anyone want to reverse the mod?! If you really want, you could cut the old female light connectors off with a bit of slack and put insulated bullet connectors on either end of the cut wire, so it can plug back in. Then cut the spades off the uprated loom and put insulated bullets on there too - voila a swappable loom that's insulated 8) Quote Share this post Link to post Share on other sites
