VRTrickster 0 Posted March 30, 2006 Yeah that is right but all you have to do is make the fixing holes longer on the car ,to get more up or down movement to align them ! I didnt bother as mine arent too bad which are FKS ,which are apparently better fitting than the IN PRO ! Quote Share this post Link to post Share on other sites
Dredgey 0 Posted April 3, 2006 If you're going to spray them black, there's always the smoked option??(although still slightly 'crystal'- ish) Venom do these for £190?. I have the FK crystals on the rear of mine and although they weren't spot on for fitment originally, with a little common sense they were adjusted and now fit completely fine. So far after a year, no misting either. I've heard that both FK and In-pro ones are common to this. The only problem i've had thats similar, is some gunk getting under the lense near the seam which was sorted with a quick blast from the pressure washer. Quote Share this post Link to post Share on other sites
Furkz 0 Posted April 3, 2006 got a set of those in the send gathering dust Quote Share this post Link to post Share on other sites
RADO.001 0 Posted April 6, 2006 i think the smoked option would look ok. has anyone got them on there C, if so have you got any pics? and has anyone ever seen smoked front fogs and indicators on a C to? Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted April 7, 2006 Heres a picture of mine! Could do with lining up a bit better,but does nt bother me too much! they are FK. Quote Share this post Link to post Share on other sites
RADO.001 0 Posted April 7, 2006 looks good mate, great colour C too. Quote Share this post Link to post Share on other sites
RADO.001 0 Posted April 7, 2006 cheers mate, ill check it out. Quote Share this post Link to post Share on other sites
Ryan S 0 Posted August 15, 2006 Heres a picture of mine! Could do with lining up a bit better,but does nt bother me too much! they are FK. Are these the smoked FK's? If so, was expecting them to look darker... :roll: Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted August 15, 2006 Yes me to! They are the FKs but I here the In Pros are a bit darker . Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 18, 2006 Backtracking a little bit here. Im in the process of doing a set of rear lights red. Have seen the guide on here advising using stripes to allow the orange through. Has anyone striped them all the way round i.e over the reverse lights or have they just done the corner indicator part and left the reverse lights white?? I think id like to colour the reverse light but wonder what the stripes would look like. Has anyone got a close up photo to give me an idea?? Quote Share this post Link to post Share on other sites
peanut 0 Posted August 18, 2006 I had a set of the smoked crystal rears on one of my old rado's. Defo thought they couldve done with being a fair bit darker. Heres the ones i did on wedge. Tinted the top half red using pinstripe tape over the reverse light to create the stripes. Peel this off then laquer over the whole lot. Couldve done with wet and drying again once the laquer had gone off. Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 18, 2006 peanut, they look ace. Are those indicators striped or have you just gone with green lamps?? Quote Share this post Link to post Share on other sites
peanut 0 Posted August 19, 2006 cheers :) only striped the reversing lights. Never actually got round to puttinga green bulb in but that was the intention. Heres the FK's on my old red one Quote Share this post Link to post Share on other sites
peanut 0 Posted August 19, 2006 better pic Main thing i didnt like with the FK's was the silver coating round the edges. Looked really cheap IMO. I painted mine Metallic looked miles better. Also the fit isnt perfect but a little bit of mainulation on the locating holoes with a dremel son cures this HTH Gav Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 19, 2006 They look good aswell but i think the reds just a nice subtle change. What width of masking tape have you used? Smallest i can find in B&Q is about 15mm which is too big. Quote Share this post Link to post Share on other sites
Trig 0 Posted August 19, 2006 Goldie197, try a craft shop you can get it as thin as 5mm. Quote Share this post Link to post Share on other sites
peanut 0 Posted August 19, 2006 Didnt use masking tape, used pinstriping from any car crap shop Gav Quote Share this post Link to post Share on other sites
Furkz 0 Posted August 19, 2006 i used 1.5mm coulda done with 2mm tbh from a stationary/office shop Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 26, 2006 Quick question to anyone who has painted there standard lights red. Ive done mine, paint and laquer and they dont look very smooth. Did anyone else have the same experience?? Any advise on polishing them smooth? T cut, very fine wet and dry??? Quote Share this post Link to post Share on other sites
Trig 0 Posted August 27, 2006 It's all about building it up in very thin layers, anything too thick will end up orange peely. You might be able to use a very fine wet and dry to take a bit of the lacquer then re-lacquer it. Quote Share this post Link to post Share on other sites
mtc R32 0 Posted August 27, 2006 Flat it back down and start spraying in fine layers again.... Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted August 27, 2006 To get them lovely and shiny-smooth, give them a really good go with 1000 grit wet and dry with plenty of water. Then use 1400 grit. Then use a cutting compound such as Safe Cut (yellow bottle from Halfords) and polish the hell out of them. Quote Share this post Link to post Share on other sites
Goldie 2 Posted August 27, 2006 Have sanded them back with 1000 grit, cleaned them up and done the thin layers and now they look business. Ill give them a good polish in a couple of days once they are fully dried out. Cheers for the tips. Quote Share this post Link to post Share on other sites
Goldie 2 Posted September 6, 2006 Opening this topic up again. Have done a set of red rear clusters which im happy with but curiousity has got the better of me. Would anyone with a green C mind popping a photo of their motor on or giving me a link to a pic if theyve got the following: Red and Clear Red and smoked. Just fancy seeing what its like. Cheers Quote Share this post Link to post Share on other sites
Guest Posted October 9, 2006 I want to get a set of clear/red rear lights, FK or In.pro don't really mind which. Where is the best place to get them from? I know they're fairly common everywhere now but who deserves my hard earned cash more? Quote Share this post Link to post Share on other sites
