The Hub 0 Posted December 5, 2006 I have a problem with my indicators not working when indicating to turn whilst driving, they work fine on the hazzards and when arming/disarming the alarm. There is a permanant slight glow to the indicator dash light when the ignition is on, and this goes to permanant full glow when you indicate but no lights come on. The dash light flashes when on hazzards or alarm :? Similar to this problem http://the-corrado.net/.archive/forum/viewtopic. ... +indicator I have taken all the fuses and relays out as that thread suggests and checked that they are ok, all bulbs flash on hazzards and alarm. So does anyone else have any other suggestions? Quote Share this post Link to post Share on other sites
Slimg60 0 Posted December 5, 2006 Indicator stalk? Quote Share this post Link to post Share on other sites
The Hub 0 Posted December 5, 2006 Would that explain the dash light though? It glows even when not using the indicator stalk! I'll give it a try but i'm thinking it something further down the line? Thanks Quote Share this post Link to post Share on other sites
Slimg60 0 Posted December 5, 2006 is it the indicator LED that glows on the dash? Quote Share this post Link to post Share on other sites
The Hub 0 Posted December 5, 2006 Yeah permanant slight glow when ignition is on and permanant full glow when using the indicator stalk. Just checked and the LED doesnt flash when using hazzards or alarm and goes of if you turn full beam on .... Quote Share this post Link to post Share on other sites
Slimg60 0 Posted December 5, 2006 I'd think maybe the stalk on even a breakdown in the plug as they're common in both indicator and headlight systems. Good luck with finding the fault, It'd be interesting to find out what it is. Quote Share this post Link to post Share on other sites
The Hub 0 Posted December 5, 2006 Cheers thanks for your help, i'll have a look at the stalk tomorrow and report back. Thanks Quote Share this post Link to post Share on other sites
Bally 0 Posted December 6, 2006 I have simliar problem.. replaced stalk no fix... Quote Share this post Link to post Share on other sites
The Hub 0 Posted December 6, 2006 Anyone else with any Ideas?? Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 6, 2006 have you tried taking each bulb out , one at a time and trying it , just incase theres a short ? take off the steering cowl and spray electrical cleaner or wd40 on the stalk contacts Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 6, 2006 i'm not sure if the indicators and hazards use the same relay , i dont think they do which means the relay is a possibility Quote Share this post Link to post Share on other sites
The Hub 0 Posted December 6, 2006 Cheers GIXXERUK, I'll try the bulbs and the electrical cleaner on the stalks, but I have already tried all the relays and fuses and all seem to be intact :? Quote Share this post Link to post Share on other sites
dr_mat 0 Posted December 6, 2006 Check all the bulb mountings - it's easy to bend a pin and short across to one of the other circuits. I had this, turned out the indicators worked perfectly, as long as I wasn't on the brakes. Have you had the light clusters out recently? If so there's your culprit. Quote Share this post Link to post Share on other sites
Andy665 0 Posted December 6, 2006 The hazards and indicators definitely use different relays, the relay on my Blue G60 worked loose once and the indicators stopped working, IIRC the relay is on the top row and is closest to the side of the car Quote Share this post Link to post Share on other sites
The Hub 0 Posted December 6, 2006 I haven't been near the light clusters, but I'll check it out anyway. Thanks for the ideas. Quote Share this post Link to post Share on other sites
The Hub 0 Posted December 6, 2006 Andy665 said: IIRC the relay is on the top row and is closest to the side of the car Just checked this relay and your right it is the correct one, but still no joy :( To wet outside to check the bulbs and stuff at the minute. Quote Share this post Link to post Share on other sites
herisites 0 Posted December 6, 2006 Are you sure its not just a BMW, the indicators never work on them :lol: Quote Share this post Link to post Share on other sites
GIXXERUK 0 Posted December 6, 2006 how do you know the relay is ok The Hub, , the often carbon up on the contacts or due to age they get dry joints Quote Share this post Link to post Share on other sites
Bally 0 Posted December 7, 2006 Andy665 said: The hazards and indicators definitely use different relays, the relay on my Blue G60 worked loose once and the indicators stopped working, IIRC the relay is on the top row and is closest to the side of the car Interesting will have a look at that 2mrw.. borrowed a bentley manual too so see if I can sort this!! Quote Share this post Link to post Share on other sites
fla 9 Posted August 2, 2022 I have replaced my rear indicators with leds. But if i press the brakes with the indicators on they stop working. Perfectly fine with normal bulbs though. And in fact with some other less bright leds they were also ok. So it seems they get shorted out when the brakes are applied. Tried turning them too but that didnt work. Any suggestions? I have all red rears so need the ultra bright leds to flash orange, normal bulbs don't really work.. Quote Share this post Link to post Share on other sites
fla 9 Posted August 2, 2022 Ah schoolboy error! The two spade terminals BR and 31 are extremely close together. I was using a spade connector too large for the terminals and this was shorting across. Back to o-level basics for me! Quote Share this post Link to post Share on other sites
Cressa 46 Posted August 3, 2022 🤣🤣 atleast you sorted it 👍 Quote Share this post Link to post Share on other sites
tonedef 10 Posted August 4, 2022 On the subject of indicators, do everyone else’s make noise? Mine are silent when flashing but I don’t remember if it was always that way, has my relay lost it’s click??? Quote Share this post Link to post Share on other sites
fla 9 Posted August 4, 2022 Mine click- without the fusebox cover its significantly louder! Quote Share this post Link to post Share on other sites
tonedef 10 Posted August 4, 2022 On 8/4/2022 at 7:16 AM, fla said: Mine click- without the fusebox cover its significantly louder! Thanks Hasan, I'll start searching through my spare relay collection for one with a click then! Quote Share this post Link to post Share on other sites
