Loud VR6 0 Posted December 18, 2006 I have noticed that my drivers door has droped ever so slightly and this mean i have to slam it rather than close it gentely ... its a 1993 vr has any one else had this problem and has any one managed to fix it .. Quote Share this post Link to post Share on other sites
Son of a Beesting 0 Posted December 18, 2006 I would be interested in this as I dont think my drivers door sits properly either as I have to bang it to close it Quote Share this post Link to post Share on other sites
fla 9 Posted December 18, 2006 Easy fix, although you need two people: loosen the top door bolt by the frame a few turns. Cut an N-shaped shim from some thin sheet steel, only a few mill mind you. Lift eh door slightly to allow some clearance and drop the shim in. Tighten. And your door should now be OK. Make sure you oil the door pins. Best way here is to use some penetrating oil first. Once this has gone in, use a general purpose oil which will then be pulled in more easily. HTH. Quote Share this post Link to post Share on other sites
daves16v 1 Posted December 18, 2006 I've got the same problem, have ordered 2 new door pins from VAG. Quote Share this post Link to post Share on other sites
fla 9 Posted December 19, 2006 How much were they? Do you fit them using a socket and press them in? Quote Share this post Link to post Share on other sites
daves16v 1 Posted December 19, 2006 How much were they? Do you fit them using a socket and press them in? £3.53 + vat each. Don't know how to fit them though :roll: Quote Share this post Link to post Share on other sites
Loud VR6 0 Posted December 21, 2006 i might buy the new pins from VAG and whils i am at it i might replace the check strap between the door and car as mine clicks ... has any one fitted one of these yet ????? Quote Share this post Link to post Share on other sites
-Neil- 0 Posted December 21, 2006 ask jason, im sure he has in his old age. Quote Share this post Link to post Share on other sites
daves16v 1 Posted December 21, 2006 Picked my pins up from VAG this week, they had to order them. I'll try to get them fitted over the Xmas holidays. Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 22, 2006 All you need to adjust the door pins is a big spanner - just loosen them and they move around. Put it in the right place, tighten it up and Robert is your mother's brother. To change them, just unscrew them until they come out - the nut that they screw into is loose, but retained so won't disappear. Quote Share this post Link to post Share on other sites
fla 9 Posted December 22, 2006 dinkus, i think its the door hinge pins being referred to not the door lock pins :wink: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 22, 2006 Interesting thread. Fla is bang on the money with his post ;-) My driver's door has sagged too.....too much use and too much speaker and dynamat weight, LOL!! Oiling is critical, but getting to the pins through the tight gaps of the hinges isn't easy, so white grease in a spray can is probably best. Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 22, 2006 dinkus, i think its the door hinge pins being referred to not the door lock pins :wink: Er *cough* yeah, I read all of this thread before posting my reply - honest :oops: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted December 22, 2006 No you didn't you lightweight, gorilla looking, poncey, gay old bastard, cheesey, eggy, smelly old bastard f'ckler bastard f'cker with pink hair! :lol: Quote Share this post Link to post Share on other sites
dinkus 10 Posted December 22, 2006 I would like to take this opportunity to point out that I don't have pink hair. any more Quote Share this post Link to post Share on other sites
Charleyvr6 0 Posted July 24, 2007 Is it really that simple just to undo the bolts and adjust it and tighten back up ? I've recently been contacted by 2 CCGB members who's mechanics have both been baffled as to how to do this. Anyone know the part numbers for the pins and bushes (if it has bushes that is) Thanks Charley. Quote Share this post Link to post Share on other sites
