latestarter2
washer liquid
I'd say it's purely down to the fact that the cabins air intake is just under the windscreeen and the smell of the washer fluid is getting pulled in when you squirt... my 55 plate Passat did the same
Nothing to worry about IMO.
I would say that applies to most, if not all, of the cars we have owned over 30 years.
If you have a partly volatile liquid splashing about on the windscreen and elsewhere, the scent of it is bound to be drawn into the car on many occasions. Surprised you have never noticed it before.
I get a pretty strong smell of washer fluid in the car on the Corrado, Bora and Passat. I always use the VW fluid and its got a nice whiff to it so I don't mind, generally use a 50/50 split at this tme of year as well
Not sure TBH, its quite cheap (£3 a bottle I think) and comes VW branded, usually found on the parts counter - superb stuff and would not use any other now
I think I read somewhere that VAG's newest washer fluid has been formulated to avoid the problem of blocked jets somehow.
