Stan 24v 0 Posted January 27, 2007 ChrisP have you still got it? Quote Share this post Link to post Share on other sites
tonedef 9 Posted January 29, 2007 You don't only have to look for Passats, they must be pretty common through the entire range as my S3 has one too. It fastens up with a single screw rather than clipping to the light but I'm sure it would go into the Corrado with bit of ingenuity. P/N 8D0 858 555 Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 29, 2007 You don't only have to look for Passats, they must be pretty common through the entire range as my S3 has one too. It fastens up with a single screw rather than clipping to the light but I'm sure it would go into the Corrado with bit of ingenuity. P/N 8D0 858 555 yeah-but, the passat one is designed to clip to the front of the sunroof motor cover, which is the same part on the Passat and C, so it clips on quite neatly, the one on my mk4 golf is totally different as the roof lining and motor cover are a different design. Quote Share this post Link to post Share on other sites
G60 CS 0 Posted November 6, 2011 Any more detail on how the early type clip on ? Spent half hour faffing with mine and its still on the back seat ! Quote Share this post Link to post Share on other sites
quicky1980 0 Posted November 6, 2011 remove the panel to the sunroof motor. its clips onto the edge, then refit. Quote Share this post Link to post Share on other sites
dragon green 4 Posted November 6, 2011 Take the interior light out,undo the two screws that hold the sunroof motor cover up,disconnect switch, Now you have the cover off,just push visor on (as in pic) then follow steps in reverse order,you done Beaten to it Quote Share this post Link to post Share on other sites
quicky1980 0 Posted November 6, 2011 lol, yeah but you explained in much better detail Quote Share this post Link to post Share on other sites
