stevef182
what size tyres??
i need some new rubber for my 17'' borbet As. theyre 7.5'' wide and one garage told me i could have either 205/40/17s or 215/40/17s but another said that the 205s would be too narrow for a 7.5 inch wide wheel and would not be possible!
any suggestion on what would be best as dont want to waste the money as we all know, tyres aint cheap!
2nd what RS VR6 said the 205's will be fine, sounds like the garage is just being a bit over cautious!
Another 205 user on 16x7.5's, only a slight stretch which means you loose a little of the tires rim protection.
thats what i kinda thought, but this guy was so sure, he said theyre was no way it would fit so i thought id check..thanks all!! RS VR6, i want some of ur rims!!! they are my dream wheels!
Hey this may help,it`s a pic of a 205 and a 215 side by side,both are x40 x17.It shows the difference in width between the two.Hope this helps :?:
so having establisehd that 205 and 215s are both an option what would everyone recommend..considering the car is - 80mm???
Go for 205's if the car is that low. I had 205/40 16's on my 9's and they were fine. Just don't get to close to curbs!
