raddo-dave 0 Posted July 19, 2007 i am looking at going for bigger bottom end for my g60 and wanted to know if there is a 2ltr bottom end from another car i can use as a starting point and what pistons and crank to use,any other relavent info would be much appreciated thanks :D Quote Share this post Link to post Share on other sites
_leon_ 0 Posted July 19, 2007 check the for sale section - few engines going including a full g60 re-build Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted July 19, 2007 _leon_ said: check the for sale section - few engines going including a full g60 re-build Ahem!!!! FULL PG 2031cc MONSTER ENGINE! - All finished done and rady to drop straight in and enjoy! Quote Share this post Link to post Share on other sites
raddo-dave 0 Posted July 20, 2007 Blue_Joe said: \ said: check the for sale section - few engines going including a full g60 re-build Ahem!!!! FULL PG 2031cc MONSTER ENGINE! - All finished done and rady to drop straight in and enjoy![/quote:1e881] thanks but i only really need a bottom end as my head has been fully done and i dont think you would be willing to split the engine Quote Share this post Link to post Share on other sites
flusted 0 Posted July 20, 2007 if my 1.8 bottom end blew, id go 2e with stacked gaskets just to see what would happen Quote Share this post Link to post Share on other sites
g60bv 0 Posted July 22, 2007 why not just buy the engine above and sell your head. that engine is a proven beast. it makes perfect sense. dont loose sight of your ultimate goal. its easy to try to get things cheap but isn't so in the long run. i know. Quote Share this post Link to post Share on other sites
CTWG60 0 Posted July 25, 2007 I don't think anyone has come up with an off the shelf 2ltr bottom end for a g60. Thay always seem to be custom, and that means they never use cast pistons in them. Stacked gaskets is a bad idea you'll have valve timing, flame travel and detonation issues not to mention bad fuel economy. :lol: Quote Share this post Link to post Share on other sites
g60bv 0 Posted July 26, 2007 tsr do one. it uses a 82mm ( i think, could even be a 81.5mm!) piston and a longer crank ( pos a diesel) . they had one at inters on there stand to take away on the day at 1500. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted July 26, 2007 g60bv said: tsr do one. it uses a 82mm ( i think, could even be a 81.5mm!) piston and a longer crank ( pos a diesel) . they had one at inters on there stand to take away on the day at 1500. Yeah but that uses a diesel block that doesn't have the oil squirters and often results in the engine going bang!!! Do you not think that if there was an easy option I would have taken that rather than the cost and heartache and time (a year!!!) to build mine to a full 2ltr spec!!! g60bv said: why not just buy the engine above and sell your head. that engine is a proven beast. it makes perfect sense. dont loose sight of your ultimate goal. its easy to try to get things cheap but isn't so in the long run. i know. You couldn't split the head off mine and use your own as mine has been specifically matched to the block as to create such a monster everything had to be set up to work perfectly with each other. The Valve pots on mine are increased to create extra cc's to assist with compression. However my head is FULLY done to as far as possible. Everything is matched up. After all the components were sourced and put together it was all lightened and perfectly balanced. You'd be better off if you bought mine, selling your head. You'd get good money for it though! Quote Share this post Link to post Share on other sites
flusted 0 Posted July 26, 2007 he ment sell his own head, not split your engine Quote Share this post Link to post Share on other sites
g60bv 0 Posted July 26, 2007 correct. i have already commented that he would be better off getting your engine. i have just had mine rebuilt with 83mm pistons and a cnc head. but i'm having difficulties putting the milage on. thats one thing people dont relise. you need to spend 500 quid on fuel just to run it in after spending £3k on the engine. then the remap. if i could go back in time, i would have bought yours or simular.. building one your self is great and can be hands one. but is no way cheaper. . Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted July 26, 2007 g60bv said: correct. i have already commented that he would be better off getting your engine. i have just had mine rebuilt with 83mm pistons and a cnc head. but i'm having difficulties putting the milage on. thats one thing people dont relise. you need to spend 500 quid on fuel just to run it in after spending £3k on the engine. then the remap. if i could go back in time, i would have bought yours or simular.. building one your self is great and can be hands one. but is no way cheaper. . To run mine in I spent 5 days doing a big circular trip alternating it each day going from Birmingham to Manchester, across to Leeds and back down to Birmingham. On the other day going from Bham to London down the M40 across the M25 Up the M1 and back across to bham. While doing this you need to keep accelerating and letting off to keep the engine under load rather than just doing a nice easy journey so it runs in properly and the piston rings seat properly. It's a bloody nightmare and bloddy boring. I had to get 1500 miles on it before remapping it. As g60bv said it was bloody expensive as the car isn't running effeciently so drinks fuel and is also bloody boring and tiring as I needed to do it in the evening to ensure I didn't get snarled up in traffic!!! Quote Share this post Link to post Share on other sites
CTWG60 0 Posted July 26, 2007 Bloody hell! I thought you just had to drive it normally and keep it under a certain revs! Quote Share this post Link to post Share on other sites
junkie 0 Posted July 26, 2007 CTWG60 said: Bloody hell! I thought you just had to drive it normally and keep it under a certain revs! No no no, need to drive at varying revs to bed it all in properly. When doing mine it was a 100 mile drive home on the A1 and i was told not to abuse it but when going along keep going into a lower gear and so on speed up slow down all in diff gears etc, (im not painting too good a picture here) but u get the idea. Quote Share this post Link to post Share on other sites
g60bv 0 Posted July 26, 2007 it is WELL boring. i insure my car for 3k miles a year. and i've only done 8k since owning it 8 years. so to put the number of miles on was hard work. i've done 1600 now and its been mapped but it still feels like it is driving with 4 people in the back. cheesed off with it. if you can buy a built engine, save the agro. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted July 26, 2007 shouldnt yours feel like a bloody rocket? Quote Share this post Link to post Share on other sites
DANG60 0 Posted July 26, 2007 g60bv said: it is WELL boring. i insure my car for 3k miles a year. and i've only done 8k since owning it 8 years. so to put the number of miles on was hard work. i've done 1600 now and its been mapped but it still feels like it is driving with 4 people in the back. cheesed off with it. if you can buy a built engine, save the agro. Do you have any details on your G werks engine? Im hoping to go that way with mine. Think ive done mine the wrong way round tho as i bought a screw charger first. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted July 26, 2007 DANG60 said: g60bv said: it is WELL boring. i insure my car for 3k miles a year. and i've only done 8k since owning it 8 years. so to put the number of miles on was hard work. i've done 1600 now and its been mapped but it still feels like it is driving with 4 people in the back. cheesed off with it. if you can buy a built engine, save the agro. Do you have any details on your G werks engine? Im hoping to go that way with mine. Think ive done mine the wrong way round tho as i bought a screw charger first. Are you sure you wouldnt fancy mine?? I'm on the sales pitch again as I need to sell it!!!! Woudl suit a screw charger perfectly as that was the last charger I had running on it! Quote Share this post Link to post Share on other sites
DANG60 0 Posted July 26, 2007 Lol, if i had the money then i would. I just dont have 3k at the mo. My only way is a bit at a time. I bet yours was a right monster with that engine and charger. Quote Share this post Link to post Share on other sites
Blue_Joe 0 Posted July 26, 2007 DANG60 said: Lol, if i had the money then i would. I just dont have 3k at the mo. My only way is a bit at a time. I bet yours was a right monster with that engine and charger. Was Mentalist! Quote Share this post Link to post Share on other sites
double-6s 0 Posted July 26, 2007 CTWG60 said: Bloody hell! I thought you just had to drive it normally and keep it under a certain revs! You should see the Stealt new VR6 running-in procedure!!! 500 miles at no more than 3000 revs Oil and filter change 500-1100 miles at no more than 3500 revs Then for each 100 miles increase max revs by 100 until you get to 5000 revs/2600 miles !!!!!!! It nearly killed me :) Quote Share this post Link to post Share on other sites
junkie 0 Posted July 26, 2007 Jeeeeesus man that would do my head in and with how much i drive it now would take 6-12 months. Quote Share this post Link to post Share on other sites
CTWG60 0 Posted July 26, 2007 double-6s, I could deal with that sort of procedure for a couple of months than driving around on motorways all night for a week! Quote Share this post Link to post Share on other sites
double-6s 0 Posted July 26, 2007 IHIG60 said: Jeeeeesus man that would do my head in and with how much i drive it now would take 6-12 months. Took me about 6 weeks :) (and lots of Optimax/money/limbs) :) Quote Share this post Link to post Share on other sites
dirtytorque 0 Posted July 26, 2007 double-6s said: CTWG60 said: Bloody hell! I thought you just had to drive it normally and keep it under a certain revs! You should see the Stealt new VR6 running-in procedure!!! 500 miles at no more than 3000 revs Oil and filter change 500-1100 miles at no more than 3500 revs Then for each 100 miles increase max revs by 100 until you get to 5000 revs/2600 miles !!!!!!! It nearly killed me :) how to torture a corrado owner. Written by stealth. Quote Share this post Link to post Share on other sites
