Dutch24V 0 Posted October 1, 2007 Is this a normal occurrence after lowering the car (about 40mm)? I've had a look and there is very little space for vertical movement of the exhaust over the rear sub frame. It will either hit the bottom of the floor or the top of the sub frame. Any solution other than an after-market exhaust? The OEM pipe bends up and then down just after exiting the rear suitcase silencer thus leaving very little room for travel. Dutch Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 3, 2007 Sounds like an exhaust fitment issue, not quite lined up properly. There should be about 10mm gap between the top of the pipe and the floor and the centre of the pipe's bend should be precisely above the axle, if that makes sense? I have a non crimped 2.5" bore pipe going over the axle and it doesn't knock and I'm minus 50mm. Quote Share this post Link to post Share on other sites
VEEDUBBED 0 Posted October 4, 2007 I've got a true 74mm exhaust from front to back and my corrado,it's also lowered on FK coilovers,it's all in the fitment and alignment,at first it did foul the back axle badly but after cutting,welding measuring loads of times i eventually got it right,ok sometimes when i hit a large pot hole it will touch but nothing serious. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted October 4, 2007 A Side exit will get round that problem :lol: Quote Share this post Link to post Share on other sites
Jay2 0 Posted October 4, 2007 My C is lowered mate and I had the same problem with my exhaust clunking over bumps on the frame. But just had a new set of rubber hangers put-on and the problem was solved. :D They weren't knackered but the slight sag made all the difference to clearance when you were sat in the car. Maybe worth a quick check. Quote Share this post Link to post Share on other sites
tim20vt 0 Posted October 6, 2007 myn used to hit with a magnex and as low as it will go on coilovers,i just put pipe clips round the rubbers to stop the zorst dropping down so mutch,been sound for 2 years :D Quote Share this post Link to post Share on other sites
tonedef 10 Posted October 6, 2007 Mine's pretty low on coilovers and I used to get probems with the magnex hitting the body or rear axle. I ended up fitting extra rubbers wherever I could just to stop the exhaust bouncing so much over bumps. Quote Share this post Link to post Share on other sites
Dutch24V 0 Posted October 12, 2007 Excellent, thanks for the response guys (...I kind of forgot I posted this question tbh :oops: ) It does stick out a bit more at the back than normal after fitting the twin cats, so it would seem if I remove an inch or so off the joining pipe in the middle it shouldn't knock anymore as the bendy bit will be pulled forward into the right place. Dutch Quote Share this post Link to post Share on other sites
