Rocket Ron 1 Posted February 15, 2017 Love the photos would look great in the 2018 30th Anniversary CCGB Calendar. Send them to [email protected] Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 15, 2017 A good one for July then Ron 😉 Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted February 21, 2017 Kip if you have a hi resolution copy could you send it to the email address and put it with all the others I have so far. That's if your happy to do that. Ron Quote Share this post Link to post Share on other sites
KIPVW 0 Posted August 9, 2017 Had a good tinkering with the Daily this morning fitting some new Bilstein B4 dampers on the rear. Jim's old Koni's finally gave up Very pleased with the condition of the arches too which look great considered they are 23 years old Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
ChrisL 20 Posted August 9, 2017 Looks in really good shape. How did you get on at tattoo this year? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted August 10, 2017 Yeah was surprised to see it as good. Tatton, was runner up to Jude Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
KIPVW 0 Posted August 23, 2017 A little tinker with the 8v again today to change the track rod ends. One was totally shot so did them both for good measure anyway. Was a nice little job that took an hour maximum. Strongly recommend getting one of the Clarkes ball joint tools first though. Absolutely brilliant piece of kit right up there with the irwin bolt grippers Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
ChrisL 20 Posted August 23, 2017 Looks as clean as the black one now with those new track rods! Quote Share this post Link to post Share on other sites
KIPVW 0 Posted August 23, 2017 Lol about the only bit that is Chris Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
KIPVW 0 Posted November 22, 2017 Well just waiting for the call of Corrado Doom from my local garage as I think the Head Gasket has gone and with 185k on the clock it probably isn't worth fixing it. It's been the best of the 8v's I've had though so a shame really. I don't have time or want to have a go myself at this time of year so if it's going to be costly i'll probably break it :( Quote Share this post Link to post Share on other sites
fendervg 33 Posted November 22, 2017 Ah, you should give it a go rather than breaking it if it's in otherwise decent nick. 8v head gaskets are an easy job - I did one on my Golf with the engine in in half a day. Best to do the timing belt and check the water pump as well at the same time. Quote Share this post Link to post Share on other sites
KIPVW 0 Posted November 22, 2017 I know and if it was summer I would probably do it. Cost is around the £650 area including all bolts gaskets a new pump and cambelt etc too. Not sure what to do but mileage is putting me off saving it. Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
ChrisL 20 Posted November 22, 2017 Such a shame to break it. You could always use the black one as a daily! Quote Share this post Link to post Share on other sites
KIPVW 0 Posted November 22, 2017 Such a shame to break it. You could always use the black one as a daily!Lol yeah yeah. Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
delfinis38 1 Posted November 23, 2017 Such a shame to break it. You could always use the black one as a daily! Good thought ha ha.. how's the mk 1 gti. Quote Share this post Link to post Share on other sites
ChrisL 20 Posted November 23, 2017 Its getting there slowly and growing arms and legs! don't know how to post pictures now so not updated. Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 23, 2017 I have a full engine here kip which could be used? Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
KIPVW 0 Posted November 23, 2017 Its it a 2E Engine mate not an ADY? Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
lilfuzzer 1 Posted November 23, 2017 Good question mate I will check for you. Sent from my SM-G357FZ using Tapatalk Quote Share this post Link to post Share on other sites
KIPVW 0 Posted November 23, 2017 Thanks. Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 2, 2018 Busy day last Sunday doing some blingin to the front brakes ready for Stanford Hall. Turned out alright Sent from my SM-A310F using Tapatalk Quote Share this post Link to post Share on other sites
fla 9 Posted May 2, 2018 Amazing Kip. What paint did you use? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 2, 2018 Amazing Kip. What paint did you use? I use Halfords Caliper Spray, I've used it for a few years now and has a good finish to it that makes it look almost factory finish rather than the foilatec stuff I used to use that left brush marks etc. It seems to last a couple of years before needing doing again but bear in mind I don't use the car much lol! Quote Share this post Link to post Share on other sites
KIPVW 0 Posted May 2, 2018 I did the discs with it too and mask off the middle brake surface and cut an edge around it so the edges of the disc get covered too which helps with corrosion etc. I do a couple of thin layers to the discs to build it up and then leave for a day or so before driving which then takes off the remaining bits of paint around the edge to then look a neat line around the disc. :) Quote Share this post Link to post Share on other sites
vr6monkey 1 Posted May 2, 2018 Another job added to the long list - those calipers look 'sparkly' brand new!! Nice one. It sometimes surprises me just how good some of Halfords' products actually are, plus they do a decent trade discount :-) Quote Share this post Link to post Share on other sites
