Chris Langdon 0 Posted December 22, 2007 ive seen some lush cars on here that have there rear tail lights all red see pic below, and they have not tinted them with a spray how do you go about doing this? many thanks Chris L Quote Share this post Link to post Share on other sites
Jim 1 Posted December 22, 2007 They're tinted with a spray! :) Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted December 22, 2007 You can also get coloured overlays from Empire GFX. Clicky Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 22, 2007 wipe them off with brake cleaner or not much thinners,tape off all but the top part to be coated. Get some nice hot lamps(halogens) from the house and place the rear lights under the lamps to warm up by apply one coat at a time to get your desired look. I would use one that has not been tinted to grade how dark you want them. Let the lights dry under the light,so no partials of dust get stuck in the paint. If you are patient you will have OEM looking rear lights. http://the-corrado.net/wiki/index.php/T ... ear_Lights Best spary to use is Savage.imop EDIT-the link above says to wet flat the lights and lacquer them,this is not necessary,just giving the lights a good clean is all needed and using the halogen lights to warm the paint will give a mirror non lacquered finish. Quote Share this post Link to post Share on other sites
paul20v 0 Posted December 24, 2007 hi if you want hi shine put a few extra coats on leave them dry properly and t-cut them with a power polisher its makes them look oem Quote Share this post Link to post Share on other sites
MARK 16V 0 Posted December 27, 2007 Does spraying them all red cause problems with the colours of the indicators (flashing red) and reverse lights. If so is there a way round this other than pinstriping the lense. Cheers,Mark... Quote Share this post Link to post Share on other sites
Walesy 0 Posted December 27, 2007 Green bulbs might work? Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 27, 2007 my standard bulbs work like normal... :? Quote Share this post Link to post Share on other sites
MARK 16V 0 Posted December 27, 2007 my standard bulbs work like normal... :? Did you spray yours like in the link above. Good to know I won`t have to start messing around with bulbs as I intend to try spraying my lights tomorrow. Quote Share this post Link to post Share on other sites
carpoid 0 Posted December 27, 2007 I used the savage spray on mine, they looked good when i first done them, but now they've faided back to orange, so maybe clear laquer could pevent that ?? Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted December 28, 2007 If you're gonna paint them, definately use laquer. Do around 3 coats, wet and dry with 1000+ grit, then cut with a cutting compound. They'll look factory 8) Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted December 28, 2007 I did not wet flat or laquer mine and they are dust free and gleem even 4 months down the line,but what ever works to get the best result. 8) Quote Share this post Link to post Share on other sites
StormchargedVR6 0 Posted December 28, 2007 If you're gonna paint them, definately use laquer. Do around 3 coats, wet and dry with 1000+ grit, then cut with a cutting compound. They'll look factory 8) Same as mine, its best to use laquer DSCF0085.JPG[/attachment:1n4h8s8u] Quote Share this post Link to post Share on other sites
Kick Up The Rs 0 Posted January 4, 2008 I concur with Stormcharged. I gave mine several coats of tint, flatted them with 1500 wet and dry. Then 5 coats or so of lacquer and again flatted them back. I then used G10 and T-cut to bring em back to OEM style. The finish is simply amazing, even though I say myself. Jus make sure u leave the laquer for 24 hours to harden before you attack them with the wet and dry. Quote Share this post Link to post Share on other sites
carpoid 0 Posted January 4, 2008 Just an opinion but i think they look better/ more OE with the reverse lights left clear. Quote Share this post Link to post Share on other sites
mariojoshi 1 Posted January 4, 2008 Well, I bought mine off ebay, but believe they were spray tinted. The indicators DO flash red and not orange.... (unsurprisingly) I've literally just fitted these however and the problem is no more :) http://www.autobulbsdirect.co.uk/produc ... 613&page=1 & http://www.autobulbsdirect.co.uk/produc ... 656&page=1 Worthwhile mod I think..... people ARE stupid and might not realise you're indicating. Worried me slightly, anyway. Quote Share this post Link to post Share on other sites
paul20v 0 Posted January 5, 2008 If you're gonna paint them, definately use laquer. Do around 3 coats, wet and dry with 1000+ grit, then cut with a cutting compound. They'll look factory 8)no need for laquer done a set 8 yrs ago and done loads since and all still look fansastic its all in the prep make sure that you key the lamp up i use a scotch pad its not agressive but gives a good key then spray coats for effect wanted then put on 2 extra this allows for cutting them back with compound use t cut not g3 as the later is 2 coarse (after a few days of dryin of course) that will give you the oem look (you can laquer if you want but why give another layer a chance to come off as we all know what laquer is like ) Quote Share this post Link to post Share on other sites
Chris Langdon 0 Posted January 5, 2008 So how do the Overlays work then from Empire GFX do you just stick em over the lense on what? any body done this ? Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted January 5, 2008 Well, I bought mine off ebay, but believe they were spray tinted. The indicators DO flash red and not orange.... (unsurprisingly) I've literally just fitted these however and the problem is no more :) http://www.autobulbsdirect.co.uk/produc ... 613&page=1 & http://www.autobulbsdirect.co.uk/produc ... 656&page=1 Worthwhile mod I think..... people ARE stupid and might not realise you're indicating. Worried me slightly, anyway. Hi, did you fit the blubs and resistors. If so, is it easy to fit the resistors? Where do they go etc? Quote Share this post Link to post Share on other sites
paul20v 0 Posted January 6, 2008 So how do the Overlays work then from Empire GFX do you just stick em over the lense on what? any body done this ? http://www.the-corrado.net/.archive/forum/viewto ... &sk=t&sd=a try this Quote Share this post Link to post Share on other sites
mariojoshi 1 Posted January 6, 2008 After doing a search on the forum (or.. rather, a friend doing one) I found this picture. Soldered it onto the bulb holder exactly as shown. Many thanks to whomever this pic came from... can't remember off hand. Works perfectly :) Very simple. I reckon a 3yr old could solder better than me.. so if i can do it, anyone can. Josh Quote Share this post Link to post Share on other sites
C. Will Corrado G60 2 0 Posted January 6, 2008 Thanks for the photo, that's nice and simple. Ordered all the bits, so hopefully have them install very soon. Quote Share this post Link to post Share on other sites
was8v 0 Posted March 17, 2008 I got some green bulbs on ebay - they make the lights flash orange but not so bright as before. See results: viewtopic.php?f=3&t=63845&hilit=+green LED bulbs are better (make it orange and bright), but theoretically it should fail the MOT with them as they are not type approved for our age cars. But then neither will green ones but I've not had a problem. Quote Share this post Link to post Share on other sites
