bananawhip
Ebay VR6 Powerchip feedback
Mine is standard on 163k with a Milltek... 194BHP....
Standard and original ?
I don't think the exact figures mean much coming from different RR's but your peak torque is 1000 rpm higher then mine !? :shrug:
Yeah standard and original! Only thing it had prior was a full service and new plugs etc. I'm thinking that the higher torque rev range is prob due to a tired head with valve springs that are probably past their perfect best! Also at the same time the oil I had in it was 5 weight so that may be making a difference. Runs on 10 weight now but not noticed anything obvious? Still it runs beautifully, uses a little oil (even less now i've got the heavier weight stuff in it), doesn't rattle and has been perfectly reliable!
Well done VW! You have built a cracker with this one! :clap: :clap:
if you use differnt cams with this chip would that detract from its benefits ie is it a map specificaly for the existing cams? Or does that not matter?
