sikaa1 0 Posted March 8, 2008 I own a 1992 2.0 Rado which needs the passenger door replacing. Managed to locate one from a later model - '95 - and want to know if the door card (& ancillaries) are interchangeable or do I need one from the same year? I'm sure I've read it somewhere about similar body panels on all models but not too sure about inside trim etc. Help! Quote Share this post Link to post Share on other sites
chimo 0 Posted March 8, 2008 you'll have to rewire the window switch and possibly the speaker. Also you will need the late spec trims (door pull handles etc), other than that they bolt up nice... however you might want both door cards :) Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 9, 2008 It depends on whether you have the late interior or early interior, '92 was the changeover year. A quick way of telling, is that the window switches are on the doorpods on the later interiors, and on the actual doorcard on early interiors. If you have a late interior it should be a straight swap, assuming the pattern/material is the same! :) Quote Share this post Link to post Share on other sites
VR6 0 Posted March 9, 2008 Maybe I'm missing something here (surely not, I hear you cry), but the question should be whether or not the complete early door card and trim (assuming his is early) will fit a late door.... ? Shouldn't need to re-wire anything as far as I can tell because he's keeping all the interior trim the same anyway. Best case scenario, he already has a late spec door card and trim and it will fit without any problems anyway. Or is the existing door card mangled as a result of an accident or something? Quote Share this post Link to post Share on other sites
Walesy 0 Posted March 9, 2008 Haha, you're right :oops: Quote Share this post Link to post Share on other sites
dinkus 10 Posted March 9, 2008 Maybe I'm missing something here (surely not, I hear you cry), but the question should be whether or not the complete early door card and trim (assuming his is early) will fit a late door.... ? Shouldn't need to re-wire anything as far as I can tell because he's keeping all the interior trim the same anyway. Not sure if the window mech has different wiring on it, so perhaps you will need to faff about? Quote Share this post Link to post Share on other sites
sikaa1 0 Posted March 10, 2008 Cheers guys. You can view 3 pics of the door on ; http://i32photobucket.com/albums/d14/voo51/house038.jpg http://i32photobucket.com/albums/d14/voo51/house039.jpg http://i32photobucket.com/albums/d14/voo51/house040.jpg Can anyone definitely tell if the card on a '92 Rado will fit on this door? i.e. Is this door off an old or new model? Sikaa1 Quote Share this post Link to post Share on other sites
easypops 8 Posted March 10, 2008 Cheers guys. You can view 3 pics of the door on ; http://i32photobucket.com/albums/d14/voo51/house038.jpg http://i32photobucket.com/albums/d14/voo51/house039.jpg http://i32photobucket.com/albums/d14/voo51/house040.jpg Can anyone definitely tell if the card on a '92 Rado will fit on this door? i.e. Is this door off an old or new model? Sikaa1 these links dont work mate.....not for me anyway :D Quote Share this post Link to post Share on other sites
sikaa1 0 Posted March 10, 2008 Sorry guys, It should have read http://i32.photobucket.com/albums/d14/v ... use038.jpg http://i32.photobucket.com/albums/d14/v ... use039.jpg http://i32.photobucket.com/albums/d14/v ... use040.jpg Cheers. Quote Share this post Link to post Share on other sites
ben16v 0 Posted March 10, 2008 that window mech looks like a very early one sissor(sp?) lift type, Quote Share this post Link to post Share on other sites
Kempy 0 Posted March 14, 2008 I have an older 92 door card if you need one Quote Share this post Link to post Share on other sites
