davidwort 0 Posted October 26, 2008 (edited) A very worthwhile job, to remove the worn and prone-to-play adjustable steering column and replace with a fixed version. more to come, but for starters: purchase second hand: one complete polo adjustable steering column, '6N' polos, 'mk4' up to chassis no. 6N-V-300 000 (up to around 1995), must be the type with separate UJ bolted up, not integrated UJ (alternatively buy the column, lock housing etc from VW, not hugely expensive (although may be approaching £200 all in now - 2010) but not worth it from the condition of second hand polo ones I've tried, they've got no perceptible wear and the final result on the Corrado is perfect with the second hand bits) Alternatively A new Corrado/Polo steering column and lock housing (exactly the same parts as the polo, only the outer tube, below, is Corrado specific) inner column 535 419 503B lock housing 357 905 851D (also fitted to 1989 on golf mk2's, passats, mk3 golfs and 1991-2000 polos) bottom bearing 171 419 517B bottom spring 191 419 343 top spring 1H0 419 667 contact ring 811 419 548 A clamping washer N 901 824 01 spline adapter sleeve (if you can't get old one off adjustable column) 191 419 514 bolts to replace shear bolts (M8x22mm) N 014 709 1 (you need 2) parts diagram attached to second post one Corrado fixed column tube, this is corrado specific 535 419 563 upper and lower trim, early and late types available from VW for small/large hazard light 535 953 515 upper part (early dash) 535 953 516 lower (early dash) 535 953 515 B upper part (late dash) 535 953 516 B lower (late dash) a new ignition switch from VW if you haven't replaced the original Corrado one before 6N0 905 865 the polo column and corrado tube: Corrado conversion V2 (3).pdfpolo-col-and-c-tube.jpg[/attachment:296llxuk] the fixed trim looks much the same as the adjustable version but is actually a totally different fitment: Book1.pdffixed-trim.jpg[/attachment:296llxuk] remove the polo UJ, you don't need this bit, keep the spring though, it's a different length to the adjustable column one stromlaufplan_gamma4.pdfpolo-column-uj-bolt.jpg[/attachment:296llxuk] remove the polo's immobiliser key sensing ring if your car doesn't need it, late models may use one ETKA Corrado.pdfpolo-key-sensor-ring.jpg[/attachment:296llxuk] remove the polo column from it's tube, you'll need to drill off the lock housing to tube fixing shear bolt stromlaufplan_gamma4.pdflock-housing-sheer-bolt.jpg[/attachment:296llxuk] remove polo ignition switch grub screw, you can just about get a thin phillips screwdriver in here Corrado92.pdfpolo-grub-screw.jpg[/attachment:296llxuk] now if you want tpo keep your old ignition key and barrell you need to drill a hole to release the barrell, from both the corrado and polo housing: passat climatronic wiring diags.pdflock-removal.gif[/attachment:296llxuk] it's fairly easy to do, just measure from the edge of the black plastic cover around the key opening and not the start of the main width body of the casing, or you'll be 2 or 3mm out, a slightly larger hole isn't a problem, but I wouldn't go bigger than 4mm climatronic wiring-Golf from May 01.pdfdrill-lock.jpg[/attachment:296llxuk] press in the sprung tab through the hole you've drilled and the barrel will slide out 2.8l 24v Climatronic system.pdfremove-lock.jpg[/attachment:296llxuk] now we need to get the original adjustable column out first remove the fuse box cover pegs then cover then remove the 7 or so screws holding the dash under tray in put the steering wheel in straight ahead, remove the horn cover and with a 24mm socket, remove the steering wheel by the centre nut, some nuts have a separate washer, the polo one had an integrated one which is easier for refitting it's not necessary to do this but it gives a bit more room to work, it may be worth waiting to do this until you've got the UJ to column bottom bolt out, see below the stalk connector plugs pull out of the back of the switches as does the ignition switch block, there's both a press in tab on one side and a notch/nobble bit on the other side of each connector block that both need freeing before the block slides out the MFA connector wire is un-clipped from a separate connecot this is the Corrado adjustable column one and is too wide for the polo column, you need the outer sleeve from the Corrado bearing, but the inner bearing from the polo to fit snugly on the narrower fixed column.block part way down the column, there's usually 2 or 3 cable ties to cut to free the loom from the column so the column can be removed the UJ to column bottom bolt now needs to be removed, a 13mm spanner and socket will be needed here, sometimes you may need to turn the steering to get room to slide the bolt out, once the nut is off a gentle tap should knock it free and it can be removed UJ-bolt.jpg[/attachment:296llxuk] Edited February 19, 2011 by davidwort Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 26, 2008 part 2! now you need to drill the shear bolts that hold the column to the dash mounting, the top two need to be drilled, the other two should be hex head bolts, remove these after drilling the shear bolts out! Book1.pdfshearbolts-to-drill.jpg[/attachment:2hh4nxsi] carefully drill these out, unbolt the hex bolts and the column will drop down once your column is off the car it should look much like this next to the fixed column: stromlaufplan_gamma4.pdfcolumns.jpg[/attachment:2hh4nxsi] remove the bottom bearing from the adjustable column by gently prising the thin metal lip around the bottom of the tube, go round in small steps and it should pop out, you don't ned this bearing (although it is the same as the polo/fixed column one) but you do need the sleeve under it. prising out the sleeve you need for the fixed column tube: ETKA Corrado.pdfprise-c-bearing-sleeve.jpg[/attachment:2hh4nxsi] this is important, as the polo tube uses a different sized sleeve, see below: stromlaufplan_gamma4.pdfbottom-bearings-and-sleeves.jpg[/attachment:2hh4nxsi] black one is the corrado one, you need to gently push this into the bottom of the corrado fixed tube, I found the lower section of the polo tube ideal for this job! now, when you refit the corrado fixed column, you need to use the polo spring, which is longer than the adjustable column spring: Corrado92.pdfbottom-springs.jpg[/attachment:2hh4nxsi] don't forget to fit the new VW ignition switch into the fixed column before you put it in the new tube, as you can't get at the grub screw otherwise! the 3 types of switch are below, original corraod part number, the polo 6N part and the latest supplied from VW (all black) passat climatronic wiring diags.pdfswitches-side.jpg[/attachment:2hh4nxsi] climatronic wiring-Golf from May 01.pdfswitches.jpg[/attachment:2hh4nxsi] once the new fixed column is assembled it can now be installed in the car, I found the attaching of the UJ a bit of a struggle as the spring needs to be compressed to allow you to slide the UJ bolt in place, the job could do with 3 hands :) theres a couple of washers that were behind the hex mounting screws for my adjustable column, I found a couple more for fitting all four bolts for the fixed column, it looked happier like that, if you need the column lower then this is the place to pack out the mounting 2.8l 24v Climatronic system.pdfpacking-washers.jpg[/attachment:2hh4nxsi] Parts diagram (from list of parts at top of thread) c-columns.gif[/attachment:2hh4nxsi] Quote Share this post Link to post Share on other sites
Supercharged 2 Posted October 26, 2008 Great write up and pics David! Do you find it drives any better?? made a noticable difference to mine but it had done nearly 200k miles... That plastic trim is a lot more solid too, more like the MK3 Golf Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 26, 2008 astonishingly better, OK, I've done front and rear bushes, top mounts, ball joints, track rods etc over the past few years but the car has done 165K and has the original front bearings (one is starting to get noisy) and original rack and rack to column UJ. It's so much more solid and has much better feel, I wish I'd got round to doing it a year or two ago it makes the car so much better to drive. I thought it would improve things, but I was hoping to just get rid of the play when you swing on the wheel, I didn't expect the feel to be so much better to the road, you just want to continually dart it from side to side :D Quote Share this post Link to post Share on other sites
pete_griff 0 Posted October 26, 2008 great write up david - thanks very much (Pete adds another job to the list!) Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 13, 2009 Is the Polo spline the large one, or the small one ? i have an aftermarket boss thats a small spline, will i have to get the large spline boss, or do i put my old "bus" wheel back on Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 13, 2009 dragon green said: Is the Polo spline the large one, or the small one ? i have an aftermarket boss thats a small spline, will i have to get the large spline boss, or do i put my old "bus" wheel back on The Corrado uses a splined adapter - if you remove this you then have a small one underneath! Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 13, 2009 As i am collecting parts to fit the non adj. steering column, what i need to know is what size is the polo column ? as i have an aftermarket steering wheel on it,that uses the small spline,does the polo column come with the small spline,or the larger spline ? Hope this is understandable ? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 13, 2009 The polo is the same part as the Corrado one mate - see the pic above, they both have the small spline Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 13, 2009 thank you, and thanks for making this a sticky :clap: Quote Share this post Link to post Share on other sites
casual 0 Posted September 13, 2009 nice write up - looking into this. it stopped they play in the steering then im guessing? Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 13, 2009 casual said: nice write up - looking into this. it stopped they play in the steering then im guessing? not just that, but the whole wheel, column and stalks all feels much more rigid and stronger than the adjustable version, the stalks seems to operate with a more defined clunk and you don't feel like the whole thing is bending, if like me you often lean on the wheel getting in and out of the car. Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 14, 2009 To give you an idea of prices column tube- £38 stalk covers- £4.60 each ! sheer bolts -pence are the fixed column corrado columns not available ? Is that why we are using polo ones ? ordered mine today,on back order ! Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 14, 2009 Yeah the other bits a dirt cheap - just the column which is about £70 I think so most of us have found them second hand - I managed to find a brand new one at a show for a quid! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 15, 2009 One of the best mods ever :grin: Did mine eons ago and the steering has been consistently good ever since. I don't know what the deal is with the Polo stuff. I just got all new Corrado parts from the dealer and it was well under £100 for the whole lot. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted September 15, 2009 where does this make the wheel sit in terms of the adjustable top-middle-bottom settings? Quote Share this post Link to post Share on other sites
davidwort 0 Posted September 15, 2009 pretty much exactly where I used to have it before :) i.e. about in the middle, however, like I said in the original post, it's easy enough to pack out with washers to lower it some more if you prefer that. Quote Share this post Link to post Share on other sites
dragon green 6 Posted September 26, 2009 The bolt part number on page one is for the Allen bolts. the sheer bolt part number is 411417549, you need two, £1.99 each ! got a quote for the corrado non-adj column-£85.10 ! (535419503H) Quote Share this post Link to post Share on other sites
Supercharged 2 Posted September 26, 2009 Do the sheer bolts do anything in terms of safety? I just fitted 4 allen bolts in case it needed to come out again but now wonder if I should replace the 2 with sheers... Quote Share this post Link to post Share on other sites
zak 0 Posted September 26, 2009 Sheer bolts are fitted from factory for security reasons, replacing with normal bolts is perfectly fine. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted September 28, 2009 Zak have you done this mod? Quote Share this post Link to post Share on other sites
zak 0 Posted September 28, 2009 Not yet but i want to if i can find the time, was hoping to do it when i get round to fitting some winter wheels and softer springs to the kw's. Quote Share this post Link to post Share on other sites
_leon_ 0 Posted September 28, 2009 zak said: Not yet but i want to if i can find the time, was hoping to do it when i get round to fitting some winter wheels and softer springs to the kw's. If you do it - give me a shout i'll help Quote Share this post Link to post Share on other sites
zak 0 Posted September 28, 2009 sure will do, its quite straight forward. I helped take Hasan's column out so should only take a few hours at most. Quote Share this post Link to post Share on other sites
fla 9 Posted September 29, 2009 Actually Zak did that completely on his own on my car, much appreciated. The hardest part was of course the removal of the shear bolts, where access is limited even without the seat and steering wheel. I've got the shear bolts in case anyone needs them. Quote Share this post Link to post Share on other sites
