C.P 0 Posted October 23, 2009 i'm glad i looked at this thread. My steering column trim is cracked and it squeaks like crazy. It's been driving me nuts! now i have the part no's to get sum brand new pieces :D Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted October 29, 2009 Ive got a bit of a problem. Im in the process of going fixed. I have the parts stripped of the polo column but the spline adapter is damaged too much to use it! Do I order a polo adapter as I looked at the corrado one and its different? On etka both part numbers for the adapter are the same for adjustable and fixed column? Quote Share this post Link to post Share on other sites
Oliver2 0 Posted October 30, 2009 I was wondering the same thing when looking at parts? there is both a 45mm and 26mm adaptor in ETKA, which one does the fixed column use? Quote Share this post Link to post Share on other sites
dragon green 6 Posted October 31, 2009 the fixed column is exactly the same as the adjustable column ! i have an aftermath wheel and boss on mine, it fitted straight on the column,as does the Corrado splined adaptor Quote Share this post Link to post Share on other sites
VRTrickster 0 Posted November 1, 2009 So I should be able to take the adapter off the corrado one and fit it to the polo column? The only thing is it looks different in length? My polo rack is off a 94. Quote Share this post Link to post Share on other sites
dragon green 6 Posted November 1, 2009 VRTrickster said: So I should be able to take the adapter off the corrado one and fit it to the polo column? The only thing is it looks different in length? My polo rack is off a 94. yes you should be able to,there didnt seem to be as much thread as the adjustable column,i just left the thick washer off ! Quote Share this post Link to post Share on other sites
veedub16v 0 Posted January 9, 2010 is there any reason the old column can't be repaired? just seems like a lot of work to me for a bit of play Quote Share this post Link to post Share on other sites
davidwort 0 Posted January 9, 2010 firstly, the adjustable column isn't a great design and will always feel like it's got more play in than a fixed column, and secondly, the joint that provides the height adjustment is a specially designed item and riveted or pressed in as part of the whole column, I'm not saying it couldn't be rebuilt, but you'd need some specialist pressing and machining tools and to get components fabricated. If you really want an adjustable column then at least one person has made up brackets to fit an entire mk4 golf column, then you get height and reach adjustment, but that's a lot more involved. Quote Share this post Link to post Share on other sites
veedub16v 0 Posted January 10, 2010 ah fair enough. luckily my column is nice and firm so no need at the moment. Quote Share this post Link to post Share on other sites
peteg40 0 Posted January 12, 2010 can you not remove the whole steering lock rather than drilling the lock? and reuse? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted January 12, 2010 Pete - No, the reason being the lock housing is different between adjustable and non-adjustable. Quote Share this post Link to post Share on other sites
hodaz 0 Posted February 23, 2010 Will any 6n shape Polo rack do or does it have to be from that specific year? Quote Share this post Link to post Share on other sites
davidwort 0 Posted February 23, 2010 what you need is the polo column with separate UJ (as the corrado UJ is needed instead), late polos use an integrated UJ you are looking for polos up to chassis no. 6N-V-300 000 (up to around 1995), after this chassis no. columns will have the integrated UJ which cannot be used on the Corrado. you need this type: 2.8l 24v Climatronic system.pdfpolo_column1.jpg[/attachment:3tt1pwiy] NOT this type: polo_column2.jpg[/attachment:3tt1pwiy] Quote Share this post Link to post Share on other sites
Dan_Storm 0 Posted May 31, 2010 Sorry to resurrect an old thread. My steering is not what it used to be and I'm getting a clicking/clonking from the top UJ of the column. Does anyone know if the replacement procedure is identical if a fixed Corrado column is used rather than a Polo column? Are the part requirements the same other than the column itself? As the cost of a new fixed column from the dealers isn't too bad I was thinking of buying new. Presumably I'd need to buy the the larger spring also? Quote Share this post Link to post Share on other sites
Supercharged 2 Posted May 31, 2010 Dan - the Polo column David shows above is the Corrado one - 535 part number... it was around £70 when I bought mine a few years ago. You need a few other bits like lock housing, sleeve, new ign switch, bearing, spring, plastic cowling - all in it comes to around £200 Quote Share this post Link to post Share on other sites
Dan_Storm 0 Posted June 1, 2010 Thanks Supercharged, don't suppose you have the part numbers for the lock housing, bearing and spring? Quote Share this post Link to post Share on other sites
davidwort 0 Posted June 1, 2010 I've updated the original 2 postings with details of all part numbers (springs, washers etc.) and a parts diagram should anyone want to buy all new parts. I still recommend getting a mk4/6N polo (to '95) column second hand as it comes with all the bits you need (bar the outer tube) and they don't really wear at all. Quote Share this post Link to post Share on other sites
Dan_Storm 0 Posted June 1, 2010 Thanks David. Great info! Quote Share this post Link to post Share on other sites
Fulltimejunglist 0 Posted September 20, 2010 Easy mate, ive jsut taken the plug off the back of the steering wheel, i know this does indicators/hazards/horn not sure of what else it powers, im currently chaning my hazard switch as the one on y steering wheel (on the top) is usless and gets stuck, ive bought a new hazard switch which im going to move to my dash (Easier acess ad will solve my problem) There are 7 wires all numberd, from what ive found out i think the 3rd and 7th are my indicators number 2 is my hazards and 1 is my horn i think, when i have my hazards on its flickers my sterio on and off whan the lights flash, do you know why this would happen and do you know which wires are the hazard wires which i can disconnect and stick the onto my new hazard switch, also i know this was due to ebing too eager but i cut some of them and if i need to put them back in, how do i remove the metal pins from the electrical plus, so i can put them back in without damaging the plastic plug? Sorry mate, its jsut i know youl have come across these whilst doing this conversion. thanks, regards Aidan. Quote Share this post Link to post Share on other sites
alip_corrado 0 Posted October 9, 2010 Hi, looks like a great mod to do and there is a P Reg (96 - 97) polo saloon in my local scrapyard. I've had a look and the UJ is definitely bolted onto the column and not integrated. Should this be OK for the job? The chassis number is WVWZZZ6KZVR012336 if that helps? :shrug: Quote Share this post Link to post Share on other sites
davidwort 0 Posted October 9, 2010 yup, isounds good, and it should be height adjustable (but not like the Corrado), the whole tube/column pivots on the UJ and is lowered and raised on it's bracket. Quote Share this post Link to post Share on other sites
Dox 31 Posted November 2, 2010 Quote once the new fixed column is assembled it can now be installed in the car, I found the attaching of the UJ a bit of a struggle as the spring needs to be compressed to allow you to slide the UJ bolt in place, the job could do with 3 hands Could you use cable ties to compress the spring to aid fitting and then cut the ties off once the U/J is bolted on or is the spring not accessable once the column is installed? Quote Share this post Link to post Share on other sites
davidwort 0 Posted November 2, 2010 TBH doing the job a second time it wasn't really that difficult, I think you'd struggle to get ties on over the column (not sure how snug the spring is over the end of the column), you'd have access to the spring once installed, but I don't think it's really worth faffing about, it should go on fine without and on your own :) Quote Share this post Link to post Share on other sites
poll250 0 Posted February 14, 2011 Since fitting my fixed column I still have a little noticeable wobble from the top of the column, I bought a replacement top bearing at the time but couldnt find a way to separate the inner fixed shaft from the part where the steering lock/ignition goes. How do you get this apart, and are there any other pieces to replace in this area? Quote Share this post Link to post Share on other sites
Rob_B 0 Posted February 19, 2011 ive just got a list of prices back from TPS using the parts listed on the first page, but I don't think he could find the corrado specific fixed outer tube part no. 535 419 536, can anyone confirm that is the correct part number please? Quote Share this post Link to post Share on other sites
