-=Kris=-
Faded plastic trim - i want it black again!
hi all...
a lot of the plastic trims on me vr are all grey and faded and i'm trying to get it back to it's former glory...
back to black is a crappy temp solution... does anyone have any ideas on a more permenant solution..?
i had someone suggest matt black spray paint!
hi all...
Other then something like Mer silicon gel or 'back to black' i think the only other option would be to spray matt black.
A lot of people have said heating up with a hair dryer brings the blackness right back.. I couldn't explain how or why this is the case tho!
Heat and then something like A-Glumm bumper care (looks like sont!) works well...
They have faded because the oils in teh plastics have leached out over time... so a case of replacing them, bit of an "Over time" process...
Or try this: Black Wow heard good things, is quite pricy but a little goes a long way...
Ive got some black wow. Its like a gel and although it works it dosen't really absorb into the plastic and remains as a gel on the surface. As such it tends to attract dust.
How about dyeing the plastic with a spray dye?
Best thing i have tried from all the trim on mk2's is boiled linseed oil. Its also alot cheaper than the "specialist" ones.
Cheers guys... i'm sure i can thief my sisters hair dryer this weekend so i'll give that a go 1st...
peanut butter is also said to have such properties
lol you can't be serious!
I used to use black shoe polish on my big bumper Mk2 Golf and it worked a treat and lasted forever once you put some bumper care or whatever on top :)
Ill be giving this a go. :D
It's the oils in the plastic that leech out over time gradually taking the black pigment with it, the more detergents that are used on the plastic the more oils in the plastic are drawn out. This is why you often find the roof spoilers the worst of the lot- because it gets more soap on it during a clean. The worst thing you can do is put silicas on it or heat it up with a hairdryer/heat gun, this draws out what oils are left in the plastic and eventually makes the problem worse, this is why they last less time in hot countries.
But the plastic doesn't only secrete oil over time, it will absorb it too, so the best thing you can do is try to put oils back into into the plastic. The vegetable oils or nut oils (hence peanut butter) will help, olive oil, liseed oil etc will all work well, and over time you will gradually reverse the process and they will stay blacker for longer. You could try putting some black dye in the oil to help it, but I've never found this to be necessary.
The best oil to use I would guess would be a thinner oil like linseed oil, my thinking being that it would be absorbed more easily, but then it may come off quicker so the plastic gets less absorbtion time. Actually heating it up and then applying oil may help but all of this last paragraph is speculation. :shrug:
There is a crystal clear coating called Back For Good - it restores and protects any colour plastic trim to its original state - this product is brilliant and simple to put on too. You can buy it online from spautopia.co.uk. It really works. :D
