g0ldf1ng3r 16 Posted November 28, 2016 new leads ordered from GSF - code blackfriday for 50% ish off - nice! Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted November 29, 2016 GSF didnt dispath the leads yesterday due to how busy they were - fortunately the HQ is only 25 mins away so ive just popped over there to collect them fingers crossed the valver will be running again tomorrow Quote Share this post Link to post Share on other sites
mic_VR 3 Posted November 29, 2016 Good work mate. Thought I'd reply in here and let that other thread die. Brakes wise, I'm not running grooves. They tend to eat pads and make a mess of wheels, plus they can be very noisy in my experience. No such luck for my old banger, he gets thrashed round a track at least once a year.... poor thing :lol: Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 Good work mate. Thought I'd reply in here and let that other thread die. Brakes wise, I'm not running grooves. They tend to eat pads and make a mess of wheels, plus they can be very noisy in my experience. No such luck for my old banger, he gets thrashed round a track at least once a year.... poor thing :lol: thanks Mic - im looking forward to their shiny yellow-ness! i agree with the grooves, not nice for a daily so back to plain discs will be nice hopefully they are only a couple of weeks away Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 GSF didnt dispath the leads yesterday due to how busy they were - fortunately the HQ is only 25 mins away so ive just popped over there to collect them fingers crossed the valver will be running again tomorrow balls - new leads fitted. they seemed to be an ok quality too. unfortunately still no joy, same event, just turning over & not trying to fire i cant hear the fuel pump when i first turn the ignition on but i cant recall how loud it was on the valver it is audible on the VR but for life of me i cant remember on the other rado guess it may have to go join the VR at the mechanics :( Quote Share this post Link to post Share on other sites
Jim 2 Posted December 1, 2016 balls - new leads fitted. they seemed to be an ok quality too. unfortunately still no joy, same event, just turning over & not trying to fire i cant hear the fuel pump when i first turn the ignition on but i cant recall how loud it was on the valver it is audible on the VR but for life of me i cant remember on the other rado guess it may have to go join the VR at the mechanics :( Have you checked to see whether you're getting fuel at all? Try cranking it over for a bit then whip out a spark plug and see if it is wet with fuel or stinks of fuel. Check the fuel pump relay? Fuses? Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 Have you checked to see whether you're getting fuel at all? Try cranking it over for a bit then whip out a spark plug and see if it is wet with fuel or stinks of fuel. Check the fuel pump relay? Fuses? fuel was my line of thought too Jim, thank you unfortunately i dont have a long enough socket to extract a spark plug & not sure where the fuel pump relay is i will have a look at fuses when i get home. its not immobiliser at it turns over ok. gona have to dig out the bentley.....manual rather than car though lol Quote Share this post Link to post Share on other sites
Jim 2 Posted December 1, 2016 Pretty sure the fuel pump relay is the bottom right most relay on all Corrado's, on the relay board. Quote Share this post Link to post Share on other sites
easypops 8 Posted December 1, 2016 Fairly sure it's got 67 on it too Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 thanks Jim & easypops - much appreciated, will check once home Quote Share this post Link to post Share on other sites
Jim 2 Posted December 1, 2016 You're not a million miles from me if you wanted to borrow a socket for removing spark plugs. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 You're not a million miles from me if you wanted to borrow a socket for removing spark plugs. bless you thanks for the offer Jim, i will give you a nod if i need to :) fortunately my dad is around at the moment so i can borrow his car to get to work - be stuck else with both rado's poorly Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 1, 2016 You could remove the fuel line where it connects to the rail . Crank it and check for fuel . From memory I think the bottom pipe is the non return. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 You could remove the fuel line where it connects to the rail . Crank it and check for fuel . From memory I think the bottom pipe is the non return. thanks rob - that is another thought i had but didnt want to attempt without another bod there as cant crank & look at the same time Quote Share this post Link to post Share on other sites
marks2 0 Posted December 1, 2016 Have you checked you have a spark at the plugs? In the summer a brand new rotor arm failed on my G60 less than 100 miles after fitting. The spark was going to earth through the distributor. Same type of symptom as you. One minute running the next not and complete refusal to start. Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 Have you checked you have a spark at the plugs? In the summer a brand new rotor arm failed on my G60 less than 100 miles after fitting. The spark was going to earth through the distributor. Same type of symptom as you. One minute running the next not and complete refusal to start. rotor arm & dizzy are on the list for tonight - thanks Quote Share this post Link to post Share on other sites
robrado974 1 Posted December 1, 2016 Put the pipe into a jam jar . Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 Put the pipe into a jam jar . clever, very! :) Quote Share this post Link to post Share on other sites
easypops 8 Posted December 1, 2016 Put the pipe into a jam jar . Eat the jam first though :) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 Eat the jam first though :) mmmm apricot on toast :D Quote Share this post Link to post Share on other sites
Jim 2 Posted December 1, 2016 Apricot and Optimax.. bleurgh! Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 1, 2016 Apricot and Optimax.. bleurgh! you are using the wrong additive Jim apricot goes lovely with VPower! must be that extra octane ;) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 16 Posted December 5, 2016 had another look at the valver on saturday i found 2 fuses blown. the 2nd 20amp in from the left & then the end right 10amp replaced with new & fired her up - no change, still just turning over checked fuel pump relay & could feel it clicking ok on ignition key - still no noise from underside though thus towed to mechanics - who now has both my rado's :( Quote Share this post Link to post Share on other sites
SR_Neale 10 Posted December 5, 2016 You now have the excuse to add a G60 to the fleet now lol. Quote Share this post Link to post Share on other sites
Jim 2 Posted December 5, 2016 You now have the excuse to add a G60 to the fleet now lol. Not sure his mechanic could keep up with the workload :) Quote Share this post Link to post Share on other sites
