Supercharged 2 Posted July 28, 2009 As some of you will know from the weekend, Bill Brockbank's (Badger5s) Ibiza had a bit of a failure in the headgasket department when going round the track at Coombe... Check these out though - genuine original VW rad and exp bottle and no hoses blew off under cylinder pressure - amazing really although not sure if this is meant to happen or not? Should it pop a core plug or hose or is it meant to stay fluid tight? Quote Share this post Link to post Share on other sites
aide 0 Posted July 28, 2009 impressive pictures :D from safety perspective i'd say it's designed to stay tight though Quote Share this post Link to post Share on other sites
shaunVR6 0 Posted July 28, 2009 good advert for the rad how it stayed in one piece :notworthy: Quote Share this post Link to post Share on other sites
millerman 0 Posted July 28, 2009 wow mental :D Quote Share this post Link to post Share on other sites
Toad 0 Posted July 28, 2009 That is quite cool. Seen a radiator from a Rover 25 like that too. Imagine if you had your head under the bonnet and it popped, like what happened with PeteGriff... Quote Share this post Link to post Share on other sites
Skimask 0 Posted July 29, 2009 That is indeed impressive! The pistons are effectively pressurising the cooling system. It is amazing everything held together. if the hoses were old - the chances are they would have blown first! Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted July 29, 2009 It's more the mental turbo boost he runs that was filling the water system and no, that shouldn't have happened, the expansion tank cap should have vented off the excess pressure long before the rad buckled. Quote Share this post Link to post Share on other sites
VR6 0 Posted July 29, 2009 I thought the thread title was radiatior bondage :( I have nothing to add in that case. Edit: After looking through Google for a bit, I might be able to offer advice if anyone's interested. Quote Share this post Link to post Share on other sites
Yandards 0 Posted July 31, 2009 kevhaywire said: It's more the mental turbo boost he runs that was filling the water system and no, that shouldn't have happened, the expansion tank cap should have vented off the excess pressure long before the rad buckled. It should have but then the radiator cap is only designed to vent excess pressure build up that occurs as part of high water temps, it's not designed to cope with a large wedge of compressed engine fuel/air mix coming into the system. It may well have been a fully open rad cap and still managed to make that much of a mess. Quote Share this post Link to post Share on other sites
