yacobwood 0 Posted April 18, 2010 Always worked fine but today when i manuly raised it, it stuck for a few seconds then went up a bit, then stuck, then went up a bit. Same for going down. Whilst driving, it goes up half way automaticly, sticks for a few seconds, then raises to top. goes down fine. Anybody have an inkling what this could be? Quote Share this post Link to post Share on other sites
lion 0 Posted April 18, 2010 might just need a bit of grease? wd-40? Quote Share this post Link to post Share on other sites
yacobwood 0 Posted April 18, 2010 o yea sorry. I also greased it quite well and still no luck Quote Share this post Link to post Share on other sites
borarob 0 Posted April 18, 2010 had this on mine, nothing to do with the mech, the motor is knackered. you either need a new motor or i think it is possible to bypass the faulty switches inside the motor that are causing the hesitation. hate saying this as it really annoys me when get it as a response, but 'do a search' you should find some info. as i say though, no amount of fiddling or cleaning the mech is gonna help with this issue. Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted April 18, 2010 Try rasing it by hand, take off the plastic cover inside the boot, pull out the knob to engage it and turn it, if its smooth and easy to turn then it sounds like the motor rather than the shafts. Quote Share this post Link to post Share on other sites
mr.ots 10 Posted April 18, 2010 I've posted on this before, should be helpful: viewtopic.php?f=3&t=83449 Quote Share this post Link to post Share on other sites
yacobwood 0 Posted April 20, 2010 Clever car. Fixed Itself :lol: Quote Share this post Link to post Share on other sites
big ben 10 Posted April 20, 2010 Clever car. Fixed Itself :lol: for now :lol: Quote Share this post Link to post Share on other sites
pumbaa 0 Posted April 20, 2010 Most likely a dodgy micro switch, mine did exactly the same. Relatively easy job, just replace the whole motor. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted April 20, 2010 Try rasing it by hand, take off the plastic cover inside the boot, pull out the knob to engage it and turn it, if its smooth and easy to turn then it sounds like the motor rather than the shafts. This /\ You'll know if the motor is struggling to push seizing cables because it will keep blowing it's fuse and get stuck. Mine kept getting stuck on the way down as it's more work for the motor against the air flow. Raising seems to be aided by air flow and it never jammed. Quote Share this post Link to post Share on other sites
