cliveyp 0 Posted January 30, 2004 Decided to knuckle down and get some of the little niggles sorted on the C. I heard a new rattle today that i wan't too happy about, so i had a look under the bonnet. Didn't find any answers to it, but i did notice that my headgasket looked like it was weeping slightly on the airbox end. :cry: What sort of cost is a new head gasket?? Also could do with a new exhaust, and what seems like a slightly lumpy tickover sorted. Is this thing gonna start draining me or what??? :roll: Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 30, 2004 They're known to weep there and it's oil that's leaking I take it? If it's just a sweat, leave it but if it's pouring out, then it will need doing. £100 odd for the gasket set + a few hours+ labour. VR6s rarely idle dead smoothly, so don't fret on that one. Quote Share this post Link to post Share on other sites
cliveyp 0 Posted January 30, 2004 what sort of prices are standard exhaust systems?? dunno whether to go stainless or keep original Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted January 30, 2004 Genuine VAG from G&S for £155, but that's less the front box. My original exhaust is still going strong at 90K, how bad is yours? Don't get me wrong, I've got rust on it and flakey metal but I aint taking it off until I absolutely have to ! I like the sound of the original one but it's your choice at the end of the day.. Quote Share this post Link to post Share on other sites
Scott 0 Posted January 31, 2004 kevhaywire said: Genuine VAG from G&S for £155, but that's less the front box. My original exhaust is still going strong at 90K, how bad is yours? Don't get me wrong, I've got rust on it and flakey metal but I aint taking it off until I absolutely have to ! I like the sound of the original one but it's your choice at the end of the day.. Mines got 111k on it and still has the original VW stickers on it :D - middle box is a little rusty but otherwise its in good nick. Will wait till it falls off then replace with a SS one. Quote Share this post Link to post Share on other sites
cliveyp 0 Posted February 1, 2004 Mine has a hole in the one box. Assuming its in the centre section, but it's the large box at the rear, in front of the back box. Would this be the £155 section? or is that just a back box? :? Quote Share this post Link to post Share on other sites
Timo. 0 Posted February 1, 2004 I'm sure I read some post on this site about lumpy idles and the guy in question had replaced the hall sender (cam position) and that had solved the problem. I know when I had my vr hooked up the the VAG thingy when I was having problems. I got error codes from the Oxy sensor and intermittent signal problems with the hall sender (G28 i think). They weren't bothered about the hall sender in the slightest but they cleared the ECU and I never really had anymore problems with performance. ta Timo Quote Share this post Link to post Share on other sites
Timo. 0 Posted February 1, 2004 Hall sender is G40 not G28. Not that it really matters Quote Share this post Link to post Share on other sites
kuksool 0 Posted February 2, 2004 VW quote me over a £1000 for a head gasket changer on a VR6 a while back!!! Quote Share this post Link to post Share on other sites
cliveyp 0 Posted February 2, 2004 Oh the joys of the VR6!! Tyres have finally arrived, so they'll be going on this week sometime. Gotta get the tracking and camber done then (after i've replaced the top mounts). Which brings me to the next question....................the best place for a pair of top mounts?? Had a weird noise this morning seeming like it was coming from either the front offside wheel bearing or CV joint, so that's in need of investigation. Decided to get all this shit sorted now before i buy a house! Quote Share this post Link to post Share on other sites
cliveyp 0 Posted February 3, 2004 The new noise is like a rhythmic metallic grinding kind of noise, the thoughts going round my head are either CVjoint, collapsed wheel bearing or a warped disk. It only does it when it's properly cold (in the morning) and is quite an obvious noise when rolling to a stop. It doesn't really change if i brake but does disappear as the car warms up. Anyone got any other ideas? :? Cheers Quote Share this post Link to post Share on other sites
dr_mat 0 Posted February 3, 2004 Pair of top mounts comes to about £30 from VW, including top mount bearings. Quote Share this post Link to post Share on other sites
cliveyp 0 Posted February 3, 2004 Actually ordered them from GS&F yesterday evening, so hat'll give me something to do at the weekend! Just this grinding noise which has concerned me a bit at the moment. Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted February 3, 2004 Are you sure the noise isn't coming from the engine? "rythmic metallic rinding" sums up a knackered upper tensioner blade perfectly. Especially so as it seems to change in realtion to the heat of the engine. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted February 3, 2004 Are you sure it's not just surface rust on the disks? Quote Share this post Link to post Share on other sites
cliveyp 0 Posted February 3, 2004 Seems to be related to road speed rather than engine speed so i've put it down to the drivetrain components rather than engine. Not surface rust on the disks though, a lot rougher than that, almost like a stone caught between pad and disk. Quote Share this post Link to post Share on other sites
Henny 0 Posted February 3, 2004 cliveyp said: Seems to be related to road speed rather than engine speed so i've put it down to the drivetrain components rather than engine. Not surface rust on the disks though, a lot rougher than that, almost like a stone caught between pad and disk. Or mud/ road crud stuck between the CV joint heat shield and the drivers side inner CV joint?!? :wink: Just a thought... 8) Quote Share this post Link to post Share on other sites
cliveyp 0 Posted February 3, 2004 Hmmmmm. Seems to have started since the snow/ice. Lump of grit in the joint perhaps? gone through a knackered cv boot?? :? Quote Share this post Link to post Share on other sites
Henny 0 Posted February 3, 2004 ...could be... [/Hong Kong Phooey] :wink: Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted February 3, 2004 Might be a long shot, but the last time mine made a noise like that the end of the CV joint had sheard clean off and the bearings were falling out! :shock: can't see it happening with the bigger VR6 ones like, but it's worth popping the wheels off and having a good look around. Quote Share this post Link to post Share on other sites
cliveyp 0 Posted February 3, 2004 Jeez Paul, don't make me worry what ever you do! :wink: :lol: Anyway, jacked it up when i got back from work. Drivers side front wheel bearing has gone somewhat AWOL! Of the road for a couple of days now till i can get it done! :roll: Quote Share this post Link to post Share on other sites
