Goldie 2 Posted January 17, 2013 The standard bottle is available, £22 ish... Quote Share this post Link to post Share on other sites
Gareth192001 10 Posted April 2, 2013 Anyone know if the vr6 rad is still available and if so where I could get it from. Rang my local vw garage drew a blank cheers in advance Quote Share this post Link to post Share on other sites
lewvw 10 Posted April 2, 2013 Think you can get hella and valeo rads from euro car parts or gsf, they're oem quality as far as i'm aware. Don't get a cheapo though, I ended up with a brazilian made one which is alot thinner. Quote Share this post Link to post Share on other sites
hulk hogan123 10 Posted May 10, 2013 could i get a price for the following please : discs front and rear. rubber for accelerator pedal. 1995 VR6 Many thanks. Quote Share this post Link to post Share on other sites
clumpy1 11 Posted May 10, 2013 Accelerator pedal is supposed to not have one you can use a golf one not sure if mk1 or 2 though for prices on disc's try euro car parts. Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted May 10, 2013 hulk hogan123 said: could i get a price for the following please : discs front and rear. rubber for accelerator pedal. 1995 VR6 Many thanks. http://www.ebay.co.uk/itm/GOLF-MK1-MK2-MK3-CAB-CADDY-CORRADO-SHARAN-POLO-T4-PEDAL-RUBBER-SET-2-PATTERN-/350564356287?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D7564213775372517054%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D350564356287%26 Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 10, 2013 (edited) Out of interest can you still get the metal power steering coolant pipe that runs into and out of the front lower radiator support panel for the VR. Edited May 10, 2013 by VWVW Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted May 10, 2013 BILLCOR said: http://www.ebay.co.uk/itm/GOLF-MK1-MK2-MK3-CAB-CADDY-CORRADO-SHARAN-POLO-T4-PEDAL-RUBBER-SET-2-PATTERN-/350564356287?_trksid=p5197.m1992&_trkparms=aid%3D111000%26algo%3DREC.CURRENT%26ao%3D1%26asc%3D14%26meid%3D7564213775372517054%26pid%3D100015%26prg%3D1006%26rk%3D1%26sd%3D350564356287%26 They're brake and clutch rubbers Bill !!!! Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 10, 2013 Was there one for the accelerator pedal?...................:shrug: Quote Share this post Link to post Share on other sites
dragon green 6 Posted May 10, 2013 seanl82 said: Was there one for the accelerator pedal?...................:shrug: No, But the Mk1 golf one fits,it's still available from the dealers Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted May 10, 2013 looks nice too :) Quote Share this post Link to post Share on other sites
seanl82 23 Posted May 10, 2013 (edited) To fit late VR6 (Brake hose may fit others) Rear brake flexi (non-sided (caliper to hard line)) - PN# 893611775A - £10.11 Late Rocker Gasket - PN# 021103483D - £15.38 Edited May 11, 2013 by seanl82 Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted May 10, 2013 dragon green said: No, But the Mk1 golf one fits,it's still available from the dealers Part No. please, I need a new one. Quote Share this post Link to post Share on other sites
Jon_vr6 1 Posted May 10, 2013 VWVW said: Out of interest can you still get the metal coolant pipe that runs into and out of the front lower radiator support panel for the VR. Thought that was a power steering pipe fella? ---------- Post added at 10:41 PM ---------- Previous post was at 10:39 PM ---------- Dude VR6 said: Part No. please, I need a new one. http://www.ebay.co.uk/itm/VENTO-SHARAN-T4-TRANSPORTER-ACCELORATOR-PEDAL-RUBBER-/251191584801?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a7c2f6821 Quote Share this post Link to post Share on other sites
VWVW 1 Posted May 10, 2013 Jon_vr6 said: Thought that was a power steering pipe fella? ---------- Post added at 10:41 PM ---------- Previous post was at 10:39 PM ---------- http://www.ebay.co.uk/itm/VENTO-SHARAN-T4-TRANSPORTER-ACCELORATOR-PEDAL-RUBBER-/251191584801?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item3a7c2f6821 Yes your right Jon. Its the power steering metal pipe What was I thinking...:) Quote Share this post Link to post Share on other sites
dragon green 6 Posted May 11, 2013 (edited) Part number 171721647. Accelerator pedal Edited May 11, 2013 by dragon green Quote Share this post Link to post Share on other sites
BILLCOR 1 Posted May 11, 2013 colinstubbs said: They're brake and clutch rubbers Bill !!!! Yeah, don't know what I was thinking about :bonk: Quote Share this post Link to post Share on other sites
hulk hogan123 10 Posted May 11, 2013 awesome guys, are the euro parts discs and pads genuine VW ones? or OEM replacements? Quote Share this post Link to post Share on other sites
Goldie 2 Posted May 11, 2013 Anyone know how much a plastic VR6 rocker cover will cost new and a part number would be great.. Quote Share this post Link to post Share on other sites
Dude VR6 0 Posted July 2, 2013 Took a trip to the dealers at lunch time to pick a few bits up, so thought I would share with you all. I needed 2 rear ABS/wheel speed sensors, both front ABS/wheel sensors. I'm going to change the bolts on all four sensors, so ordered them to, and I also ordered a throttle pedal rubber. The part No.s have changed slightly from VAGCAT, but I think you will get the gist. V171 721 647 Rubber Pad £7.29 V1H0 927 807 bA Rear Speed Sensor £99.68 VN 101 961 03 Bolt £0.38 V1j0 927 803 L/H/F Speed Sensor £60.79 V1J0 927 804 R/H/F Speed Sensor £60.79 VN 014 734 6 Bolt £.040 All prices are plus V.A.T, so I got a bit of a SHOCK, but the dealers I use give me a discount :thumbleft: Quote Share this post Link to post Share on other sites
seanl82 23 Posted July 3, 2013 That is kin nuts the price of the ABS sensors! :shocked!: Quote Share this post Link to post Share on other sites
Goldie 2 Posted October 31, 2013 After searching high and low i still cant find whether the heat shields (velcro one on fule lines to LH side of engine VR6 and the one that goes around the loom, behind engine, secured with 2 x cable ties) exist.. Does anyone know, part numbers would be great if so.. Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 31, 2013 (edited) This one fits to the bulk head / fire wall, behind engine. http://www.vw-classicparts.de/shop/ Ebay http://www.ebay.co.uk/itm/VW-Corrado-2-0-1-8-16v-G60-VR6-Heat-Shield-OEM-Exhaust-Manifold-536-803-312-/271213399208?pt=UK_CarsParts_Vehicles_CarParts_SM&fits=Model%3ACorrado&hash=item3f25940ca8 Is this the one you're after ?? Si Edited April 25, 2014 by vw rule Quote Share this post Link to post Share on other sites
Goldie 2 Posted November 1, 2013 The ones im after are the 2 soft ones, both velcro fastened although if i could find all the metal ones id probably change those as well.. Quote Share this post Link to post Share on other sites
Goldie 2 Posted November 6, 2013 On the subject of heat shields... Does anyone know what the difference is between 191803326A and 191803326B? I have found one of them but im suspicious its the wrong one... Quote Share this post Link to post Share on other sites
