ryan_welshman 10 Posted June 20, 2014 Yeh but ones I got from ebay, the clips on the back are totally different and wont fit unless I hack the body a little in order to fit Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted June 20, 2014 I have a pair of originals if you're interested? Quote Share this post Link to post Share on other sites
clumpy1 11 Posted June 20, 2014 ryan_welshman said: Yeh but ones I got from ebay, the clips on the back are totally different and wont fit unless I hack the body a little in order to fit There was some genuine one's being sold on ebay not so long ago found these http://www.ebay.co.uk/itm/SIDE-INDICATORS-AMBER-NEW-FOR-VW-GOLF-MK2-CORRADO-SCIROCCO-POLO-CADDY-CABRIOLET-/390860644159 I'll try and find the other's Quote Share this post Link to post Share on other sites
clumpy1 11 Posted June 20, 2014 diarmaid16 said: I have a pair of originals if you're interested? Sorry Diarmaid you replied while I was typing Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted June 20, 2014 Are they clear ones diarmaid? Quote Share this post Link to post Share on other sites
diarmaid16 1 Posted June 20, 2014 No worries clumpy. Ryan, no they are the original Hella orange indicators Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted June 24, 2014 Ah right, really want clear ones to replace the older ones. But cheers anyways :) Quote Share this post Link to post Share on other sites
vw rule 19 Posted June 28, 2014 Just found this on the VW Heritage site, not in the Corrado section but in the MK2 Golf section, it's the rear stub axle dirt / dust plate covers that slide over onto the inner end of the stub axle flange, they help to stop any dirt getting into the hub bearing or damaging the bearing seal. The part number is 191-501-639A and is under the MK2 Golf section but this item fits the Corrado as well. Cost of the above item is £7.10 per each. Don't forget to check the MK2 Golf section for Corrado parts as well, as some are listed there. Si Quote Share this post Link to post Share on other sites
borders16v 0 Posted June 29, 2014 Just want to say Thanks Si for your info in this thread. Bl**dy annoying that everytime i call my local dealer i get the usual "sorry obsolete pal" Lol Quote Share this post Link to post Share on other sites
ryan_welshman 10 Posted June 30, 2014 Can you give me vw part number and rough price for a 1992 2.0 16v raddo exterior fuel pump? Cheers Quote Share this post Link to post Share on other sites
vw rule 19 Posted July 5, 2014 ryan_welshman said: Can you give me vw part number and rough price for a 1992 2.0 16v raddo exterior fuel pump? Cheers Hello there, the exterior fuel pump part number is 191-906-091H and is the 60mm diameter fuel pump for 2.0 16v (9A eng code) Cost new from VW Heritage is £98.00 Or you could try Ebay I've seen the pump on there for about £58.00 Or try Euro Car Parts or GSF. One thing you'll need to replace though as well is the 3 retaining screws, that hold the pump in place, the part number of which is N104-047-01 Cost of the screws is £0.44 + VAT per each from VW Main Dealer. Normally the screws round off when removing them or the heads are badly rusted, so like I say it's always best to replace them. Hope this helps Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 4, 2014 Had a oil leak from my engine on my 2.0 16v Corrado, it was the breather hose that had split open, the one from the engine block breather housing to the air filter box. Tried my local main dealer but was told it was obsolete. Looked on the VW Classic Parts site under Corrado, Golf and VW Passat, anyway found the part under VW Passat (9A) 2.0 16v The part number is: C027-103-217/G cost is £33.55 + VAT = £40.26 Hope this helps. Si Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 5, 2014 vw rule said: Just found this on the VW Heritage site, not in the Corrado section but in the MK2 Golf section, it's the rear stub axle dirt / dust plate covers that slide over onto the inner end of the stub axle flange, they help to stop any dirt getting into the hub bearing or damaging the bearing seal. The part number is 191-501-639A and is under the MK2 Golf section but this item fits the Corrado as well. Cost of the above item is £7.10 per each. Don't forget to check the MK2 Golf section for Corrado parts as well, as some are listed there. Si Many thanks for this post Si , I'm doing this job ATM Rob Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 5, 2014 robrado974 said: Many thanks for this post Si , I'm doing this job ATM Rob Hello Rob, no worries mate hope you get it sorted. Si Quote Share this post Link to post Share on other sites
robrado974 1 Posted October 9, 2014 vw rule said: Hello Rob, no worries mate hope you get it sorted. Si The only ones they have are non abs now Si . deleted in may . I found 1 at a tps branch in Ireland ! Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 9, 2014 Ok mate thanks for letting us know. Thanks again Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted April 12, 2015 The left window regulator is now available at Classic Parts, cost is £208.25 euros = to £150.70 Part number is: 535837401A These were over £300.00 back in 2012 from the main dealer. Hopefully the right window regulator will be available soon. Also the Corrado door skins from Classic Parts were just over £500.00 a side, but I think they've dropped this part now, as the complete doors are now available, well the left door is. Cost is £299.00 euros = to £216.35 Part number is: 535831051AN (Left Corrado Door) Hope this helps. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted April 12, 2015 (edited) Also the rear light units are available at Classic Parts. The part numbers and cost are as follows. FOR ALL CORRADO'S Left rear outer light (Indicator, Brake & side with reflector) Part N.o: 535945111 £82.56 euros = to £59.75 Left rear inner light (UK Spec so just reverse no fog) Part N.o: 535945107A £72.10 euros = to £52.16 Left rear inner light (LHD Spec reverse with fog) Part N.o: 535945107 £72.10 euros = to £52.16 Right rear inner light (LHD spec just reverse no fog) Part N.o: 535945108 £72.10 euros = to £52.16 Right rear inner light (UK spec so reverse and fog) Part N.o: 535945108A £69.00 euros = to £52.16 FOR ALL CORRADO'S Right outer rear light (Indicator, Brake & side with reflector) Part N.o: 535945112 £82.56 euros = to £59.75 Hope this helps. Si Edited April 12, 2015 by vw rule Quote Share this post Link to post Share on other sites
Hairyarse 10 Posted April 12, 2015 :thumbleft: Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 12, 2015 Nice one - not seen this thread before :clap: Quote Share this post Link to post Share on other sites
Wayne2015 10 Posted April 12, 2015 Just wondering Is the 1st post to collate all parts/prices? Just that it not updated since 2011 :eek: Quote Share this post Link to post Share on other sites
beastofabug 10 Posted June 4, 2015 hi looking for 2 drivers side lupo gti wiper arms believe its part no 6x2 955 410C Quote Share this post Link to post Share on other sites
Thursdave 10 Posted June 5, 2015 Yep, Lupo GTI Drivers wiper arms are that part number. RRP £59.17 each, or PM me for a price to you using to forum discount ;) Quote Share this post Link to post Share on other sites
Rocket Ron 1 Posted June 5, 2015 (edited) If your interested and want to improve the c****p wipers and stay original I just fitted BMW E30 ones vast improvement. Much much cheaper than TT/Lupo mod. http://the-corrado.net/showthread.php?84674-BMW-e30-wipers-fit-perfect Edited June 5, 2015 by Rocket Ron Quote Share this post Link to post Share on other sites
volksworld13 0 Posted August 28, 2015 Hi wondered if you can help. I've replaced my rear drivers side engine mount on my 1991 g60 corrado. The mount is secured by three long bolt which you can reach from above. However one bolt had a stud on it which secured the oxygen sensor bracket.the stud snapped. Tps and vw can't find this bolt on the parts system . So it's basically a normal rear engine mount bolt with a stud on top. If someone could find the part number I'd Be most grateful. Cheers Quote Share this post Link to post Share on other sites
