Thursdave 10 Posted August 28, 2015 Volks - I'll have a look on tuesday when I get back into work. Dave Quote Share this post Link to post Share on other sites
volksworld13 0 Posted August 29, 2015 Ideal cheers Quote Share this post Link to post Share on other sites
Thursdave 10 Posted September 1, 2015 Hi wondered if you can help. I've replaced my rear drivers side engine mount on my 1991 g60 corrado. The mount is secured by three long bolt which you can reach from above. However one bolt had a stud on it which secured the oxygen sensor bracket.the stud snapped. Tps and vw can't find this bolt on the parts system . So it's basically a normal rear engine mount bolt with a stud on top. If someone could find the part number I'd Be most grateful. Cheers Hi Volks, just had a look and this doesn't appear to exist! When you say the oxygen sensor bracket what exactly do you mean? Can't find any sort of bracket on the oxygen/lambda sensor at all. Any chance of a picture? Quote Share this post Link to post Share on other sites
branty 10 Posted September 2, 2015 Hello, can you give me price and availability on both driver and passenger outer window scraper mouldings please? many thanks Lee Quote Share this post Link to post Share on other sites
volksworld13 0 Posted September 13, 2015 Hi This is the picture of the bolt I think it's an m12 bolt with a stud and nut on top that locate the oxygen sensor bracket. The O2 sensor connector slide in the a small metal bracket and the bolts down on top of this stud. I believe it's not listed as you've mentioned. I'm wondering if it's listed under other model years or mk 2 golf? Quote Share this post Link to post Share on other sites
Thursdave 10 Posted September 14, 2015 Found it! There's two choices, though - An M12x55 with an M8x16 on top, which is fully threaded all the way, part number N -909-678-01 or the one listed on the corrados, which is M10x55 with an M8x16 on top, which is threaded part way, part number N -911-270-01 cheers, dave Quote Share this post Link to post Share on other sites
volksworld13 0 Posted September 24, 2015 Your a star thanks. Was the n 911 bolt listed for corrado? Quote Share this post Link to post Share on other sites
Thursdave 10 Posted September 25, 2015 Yeah, the N91127001 is the one listed for the corrado, but that's M10 and only part threaded: https://c1552172.ssl.cf0.rackcdn.com/158110_x800.jpg The other one N90967801 is M12 like you said and threaded all the way, like your picture: https://c1552172.ssl.cf0.rackcdn.com/360845_x800.jpg Quote Share this post Link to post Share on other sites
volksworld13 0 Posted October 23, 2015 Hi Just one more item. I need front brake hose support brackets on my 1991 g60. Theses are bolted to the inner wing that supports the hose. I expect they are obsolete . Any help appreciated . Alex Quote Share this post Link to post Share on other sites
seanl82 23 Posted October 24, 2015 Hi Just one more item. I need front brake hose support brackets on my 1991 g60. Theses are bolted to the inner wing that supports the hose. I expect they are obsolete . Any help appreciated . Alex Isn't this part of the suspension strut? Quote Share this post Link to post Share on other sites
volksworld13 0 Posted October 24, 2015 No but I know that the later models had the bracket welded onto the inner wing.on the early corrado it's a small black retainer/support bracket that the hose/ pipe sis in. Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted November 10, 2015 Are Corrado vr6 fuel pumps still available Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted November 11, 2015 Are Corrado vr6 fuel pumps still available think so as mine went a few months ago - hot sure if the mechanic replaced with genuine or OEM though Quote Share this post Link to post Share on other sites
VR6Pete 0 Posted November 11, 2015 Ordered a Walbro 255 in tank pump now Quote Share this post Link to post Share on other sites
AndyL 10 Posted January 19, 2016 The left window regulator is now available at Classic Parts, cost is £208.25 euros = to £150.70 Part number is: 535837401A These were over £300.00 back in 2012 from the main dealer. Hopefully the right window regulator will be available soon. Also the Corrado door skins from Classic Parts were just over £500.00 a side, but I think they've dropped this part now, as the complete doors are now available, well the left door is. Cost is £299.00 euros = to £216.35 Part number is: 535831051AN (Left Corrado Door) Hope this helps. Si Any news on this? Hopefully the right window regulator will be available soon. Andy Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 6, 2017 Yes I believe only the left window regulator is available for now. Both the Corrado doors are still available at roughly €299.00 = to £216.35 per door. Si Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 6, 2017 (edited) LHD steering universal column shaft joint. Ebay item number 253015452132 £58.21 from Germany. VW Classic Parts OEM Part number 191419951B €249.00 = to £223.70 For LHD only 1983 to 1992 none power steering cars, VW MK2 Golf, Jetta. Possibly early colunm u-joint has 40 splines. Later one's possibly have 18 splines. **************************** LHD / RHD steering universal column shaft joint Ebay item number 322527854811 £53.17 VW Classic Parts OEM Part number 191419951F €60.95 = to £54.76 For LHD / RHD 1988 to 1992 none power steering cars, VW MK2 Golf, Jetta. Possibly early colunm u-joint has 40 splines. Later one's possibly have 18 splines. Hope this helps. Si Edited October 6, 2017 by vw rule Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 6, 2017 (edited) LHD steering universal column shaft joint. For Corrado with power steering & tilt up / down column. 1991 to 1995 VW Classic Parts OEM Part number 535419951C €279.00 = to £250.59 ***************************** RHD steering universal column shaft joint. For Corrado with power steering & tilt up / down column. 1989 to 1995 VW Classic Parts OEM Part number 536419951C €309.00 = to £277.57 Hope this helps. Si Edited October 6, 2017 by vw rule Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 6, 2017 (edited) I might have listed this already can't remember. Corrado. Rear washer spray jet OEM Part n.o 00-333955993 €2.75 = to £2.47 Rear wiper motor unit. OEM Part n.o 00-535955713A €219.00 = to £196.71 Plus rubber tapered washer to go with above wiper unit. OEM Part n.o 00-535955733 €2.34 = to £2.10 Hope this helps Si Edited October 6, 2017 by vw rule Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 7, 2017 (edited) New from VW Classic Parts. Front splitter retaining plate. Secures front splitter to Base of front bumper, for all Corrados 1988 to 1995. OEM Part n.o 00-535807181 €40.95 = to £36.75 Hope this helps. Si Edited October 7, 2017 by vw rule Quote Share this post Link to post Share on other sites
annavr6 10 Posted October 10, 2017 New from VW Classic Parts. Front splitter retaining plate. Secures front splitter to Base of front bumper, for all Corrados 1988 to 1995. OEM Part n.o 00-535807181 €40.95 = to £36.75 Hope this helps. Si £29.50 plus VAT (£35.40) from heritage with free postage if your order is over £35. This is in fact cheaper than classic parts and with no postage from Germany. (everyone always says bad things about us being expensive) Quote Share this post Link to post Share on other sites
g0ldf1ng3r 17 Posted October 10, 2017 £29.50 plus VAT (£35.40) from heritage with free postage if your order is over £35. This is in fact cheaper than classic parts and with no postage from Germany. (everyone always says bad things about us being expensive) hi anna i dont think that it is 'everyone saying bad things about expensive' - in general i have found Heritage to be very good value i have also found the service from not only yourself but your colleagues i have spoken with on the phone to be excellent - always very helpful & knowledgeable & to be a little blunt Heritage are massively more helpful than the local VW dealers personally, i think the 'expensive' part normally corresponds to parts you have had reproduced & also to those parts which are hard or impossible to find. obviously we all know & appreciate Heritage need to cover setup & initial order type costs but sometimes the eventual 'price' of an item can be a shock to begin with - however, when compared to the older VW part prices they are often better or very competitive again personally, i would like to thank yourself, luke, martin & george! the 2 parts Heritage sent me last week have enabled me to repair both of my rado's this weekend :D Quote Share this post Link to post Share on other sites
vw rule 19 Posted October 10, 2017 Nice one Anna thanks for letting us know, every little saving helps. P.S I'm just posting up any new part number I happen to find when looking for an item, on Classic Parts I might need in the future and just post up on this thread to help out anyone else who might need it also. Many thanks Si Quote Share this post Link to post Share on other sites
annavr6 10 Posted October 10, 2017 hi anna i dont think that it is 'everyone saying bad things about expensive' - in general i have found Heritage to be very good value i have also found the service from not only yourself but your colleagues i have spoken with on the phone to be excellent - always very helpful & knowledgeable & to be a little blunt Heritage are massively more helpful than the local VW dealers personally, i think the 'expensive' part normally corresponds to parts you have had reproduced & also to those parts which are hard or impossible to find. obviously we all know & appreciate Heritage need to cover setup & initial order type costs but sometimes the eventual 'price' of an item can be a shock to begin with - however, when compared to the older VW part prices they are often better or very competitive again personally, i would like to thank yourself, luke, martin & george! the 2 parts Heritage sent me last week have enabled me to repair both of my rado's this weekend :D Thanks, always nice to hear. We do try our best and do understand that some parts can come across expensive. I was more refering to classic parts. Sometimes alot of people think its cheaper to order direct but its usually not. Quote Share this post Link to post Share on other sites
Cressa 46 Posted October 10, 2017 I'll second everything Goldfinger has said. Always great service, patience and help. Without you we wouldn't have some of the parts we do have today. . Thank you for being there for us all. If I wanted cheap I'd buy a Ford and mod it. Cressa Sent from my SM-G900F using Tapatalk Quote Share this post Link to post Share on other sites
