biggerbigben 0 Posted March 4, 2004 What's the law on removing the indicator from a UK wing? I want to do it to smooth out the lines of the corrado.... Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 4, 2004 you need them for the mot Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 4, 2004 Technically you need a "side-visible indicator light", but it doesn't have to be where it is currently. On the whole it's probably not worth moving it, though, unless you really really want to... Quote Share this post Link to post Share on other sites
PhatVR6 0 Posted March 4, 2004 I got away with it for 4 years.... Quote Share this post Link to post Share on other sites
RACK 0 Posted March 4, 2004 I don't think it's compulsary to have one on. BUT!!!!! If you do have one it must work? Quote Share this post Link to post Share on other sites
dazzyvr6 0 Posted March 4, 2004 ,you have to have side repeaters on your car after a certain year,think it was sometime in the 80's it was made compulsary Quote Share this post Link to post Share on other sites
G60Dan 0 Posted March 4, 2004 legally anything after a "D" plate has to have them, but I have smooth wings on my C & it's MOT'd all fine. If they pull you up on it, take it for an MOT somewhere else :wink: Quote Share this post Link to post Share on other sites
dr_mat 0 Posted March 4, 2004 Up to you, but it's one of those things that a plod in a bad mood is likely to use as an excuse to pull you. I'm on borrowed time with my red rear lamps too, so I know what that means, but there ya go. Technically you're not insured if your car is not worthy of it's MOT certificate, either, so you might have trouble if something bad happens (stolen/recovered for example). Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 4, 2004 Yeah, I heard anything later than a B plate needs side repeaters but you could relocate them to the bumper (US spec) or wing mirrors! Quote Share this post Link to post Share on other sites
Banana Man 0 Posted March 4, 2004 I never had side repeaters on my golf gti it had gti plates there instead and it went through mot's fine I never got pulled by the police for them either ( loads of other things mind you :D but never the side repeaters) Best thing is to goto your local mot station and ask if they would fail the car without them! Quote Share this post Link to post Share on other sites
Phil K 0 Posted March 4, 2004 I think the general view is that if a car came with them fitted as standard from the maunfacturer then it must have them for the MOT, this means anything from D reg onwards as that was when the law changed. It's the same rule for rear seatbelts... HTH - only really repeating all above :oops: Phil Quote Share this post Link to post Share on other sites
dubster82 0 Posted March 5, 2004 im with dr mat, as its more a grey area. from a certain point, there must be visible orange light ommiting fromt he side of the vehicle. well my inpros show light from the side..... Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted March 5, 2004 dr_mat said: Up to you, but it's one of those things that a plod in a bad mood is likely to use as an excuse to pull you. I'm on borrowed time with my red rear lamps too, so I know what that means, but there ya go. Technically you're not insured if your car is not worthy of it's MOT certificate, either, so you might have trouble if something bad happens (stolen/recovered for example). I want to spray the rear lights with red laquer as well - is this illiegal??? if so why? Quote Share this post Link to post Share on other sites
Henny 0 Posted March 5, 2004 biggerbigben said: want to spray the rear lights with red laquer as well - is this illiegal??? if so why? Only if the indicators don't light up amber, or they are deemed to be not bright enough... 8) indicators must, by law, be amber and a certain brightness (21W springs to mind, but I have been to the pub tonight so I could be wrong! ;) ) Quote Share this post Link to post Share on other sites
biggerbigben 0 Posted March 5, 2004 Henny said: biggerbigben said: want to spray the rear lights with red laquer as well - is this illiegal??? if so why? Only if the indicators don't light up amber, or they are deemed to be not bright enough... 8) indicators must, by law, be amber and a certain brightness (21W springs to mind, but I have been to the pub tonight so I could be wrong! ;) ) so what about the white reverse light, can that be covered ?? so I should be ok as long as they are bright, either that or I have a spare set of rear lights for mot times.... Quote Share this post Link to post Share on other sites
chris CORRADO 0 Posted March 7, 2004 LOL volvos have em on all the time.... funny story here also lol my mates 1960's beetle has no door handels and he flys through MOT's lol i ask him if he crashes hows the amblance crew gonna get in LOL Quote Share this post Link to post Share on other sites
Dilated 0 Posted March 7, 2004 Reverse lights are not required by law - they are technically only really there to help you see where you are reversing. I have found that thiis does become a pain in the arse, as no other drivers can see that you want to reverse! (My little mk1 golf cab hasn't had the reverse lights hooked up since I bought it years ago) Quote Share this post Link to post Share on other sites
g60bv 0 Posted March 7, 2004 it's not illegal but if you spray your rear lights, you must fit another , or don't spray over the reflecter bit on the cluster, this would be an MOT failure, i've been screwed for this on my golf, i had to go to the brakers, buy a new set for the MOT, then change them again, gits :x , but some MOT staitions or on the ball , others can easily be distracted. enter girlfriend in passenger seat in a low cut top, :D , Quote Share this post Link to post Share on other sites
bigben 0 Posted March 8, 2004 best thing to do is put one small L.E.D in your wing mirror then you have a visible light from the sideeither on the end of the mirrow or on the bottom. that is what i will be doin as i have checked with th test station Quote Share this post Link to post Share on other sites
flux 0 Posted April 2, 2004 i dont have any indicators at the front at all.... Quote Share this post Link to post Share on other sites
DaveStorm 0 Posted April 2, 2004 Hmmm thats useful for incoming traffic..... :roll: Quote Share this post Link to post Share on other sites
Henny 0 Posted April 2, 2004 Hummmmmm, no indicators, therefore not fit to pass an MOT, therefore insurance is invalid... :| Likelyhood of an accident increased by lack of indicators + invalid insurance = stupid thing to do really if you're gonna use that car on the road... :roll: Quote Share this post Link to post Share on other sites
crazymarcel 0 Posted April 2, 2004 lol, bet people love u on roundabouts :D Quote Share this post Link to post Share on other sites
flux 0 Posted April 2, 2004 relax they are wired somewhere else i have them at the top of the windscreen and in the window where the door pins are Quote Share this post Link to post Share on other sites
Henny 0 Posted April 3, 2004 flux said: relax they are wired somewhere else i have them at the top of the windscreen and in the window where the door pins are Is that legal? I thought there was an area (height from floor and distance from edge of car) that they had to be... surely at the top of the windscreen is well outside this area? :? Quote Share this post Link to post Share on other sites
