corrado9a 0 Posted July 31, 2011 hi all I have been searching for a couple days information regarding swapping the gearbox from a VR5 engine into my VR6. The problem is I haven't even found information regarding the box type,let alone ratios, Does it require a new gearbox mount, custom transmisions etc... I don´t know if anyone here has made the swap, but if you can share any info it would be very very welcomed. thanks Quote Share this post Link to post Share on other sites
science 0 Posted August 1, 2011 Not fitted but remember looking into this. Afaik; V5 box has same gear ratios but lower 3.94 final drive. Same mounting points. Maybe different driveshaft flanges depending on v5 code. Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted August 1, 2011 there's a VR5 engine? Quote Share this post Link to post Share on other sites
fla 9 Posted August 1, 2011 Typically created when coilpacks go duff, lol! Quote Share this post Link to post Share on other sites
andy 0 Posted August 1, 2011 there's a VR5 engine? http://en.wikipedia.org/wiki/V5_engine Used across the range, good lumps apparently but a tad thirsty! Quote Share this post Link to post Share on other sites
Dox 22 Posted August 1, 2011 http://en.wikipedia.org/wiki/V5_engine Used across the range, good lumps apparently but a tad thirsty! http://www.scribd.com/doc/8762040/23-V5-AGZ-info-doc Quote Share this post Link to post Share on other sites
corrado9a 0 Posted November 1, 2012 sorry to bring this thread back from the dead, but i broke my clutch so it's the perfect time to tune/massage the box. Do any one know if swapping an AGZ box in a VR6 requires any custom work? (driveshafts, mounts, selector, etc..) Thanks in advance Quote Share this post Link to post Share on other sites
captainredeye 0 Posted November 1, 2012 There is some info on other threads about the 3.6 final drive from the g60! I think the v5 gear box has been mentioned apparent ly the final drive on that box will have you wheel spinning every where. Quote Share this post Link to post Share on other sites
CazzaVR 0 Posted November 1, 2012 Think there are a few threads on this over at http://www.vr6oc.com If used as a daily I'd go 3.68. Think people tend to use the 3.9 V5 for trackday/weekend cars. Quote Share this post Link to post Share on other sites
corrado9a 0 Posted November 1, 2012 i have been researching this for some time and yet i havent seen no clear answers about my question. I see more questions than answers and none is definetive as, I did that and it takes this and that. Nevertheless for all of you in the UK, i have realized that the AGK box of the euro Vr6 with a 3.68 FD is just the same as the CGY box from a 2.0 16v engine. So i think is simpler and cheaper to remove all the internals from the 9A box and swap it into the bell housing of the Vr6. Is for your information in case is valuable to anyone wanting to do a 3.68 upgrade. Cheers Quote Share this post Link to post Share on other sites
