StueyB 0 Posted February 18, 2012 (edited) BREAKING: Corrado 2.0 8v 95' Late spec/facelift - 140k - Manual - Flash Red [LP3G] Late black interior (without hump) *UPDATED - 17/04/12* ********************************************************************** LIGHTS - All Sold. EXTERIOR Rear VW Badge 5.00 (Flat, no chrome, perfect for painting) Front Windscreen Rubber Seal 10.00 Wiper Arms 10.00 (pair) Boot lock + rods 10.00 BODY PANELS - Flash Red - (LP3G) Front Bumper - Late spec 35.00 Front Bumper Iron Brackets 5.00 Bonnet Brackets 10.00 (pair) Drivers Sill Repair Panel 35.00 (no rust, perfect for repair panel) Pass Sill Repair Panel 35.00 (no rust, perfect for repair panel) Boot Spoiler 10.00 INTERIOR & TRIM [bLACK] Front Ashtray/Housing 10.00 Gearshift Tunnel 10.00 Handbrake Tunnel 10.00 Rear Ashtray 5.00 Drivers Lower Kick Plate 10.00 Pass Lower Kick Plate 10.00 Clutch Footrest Trim 5.00 Sill Plastic Covers (pair) 10.00 C Pillars 25.00 (pair + joining strip) Side Boot Carpets (2pc) 30.00 (one minor strain, could be removed) Inner Boot Lid Panel 10.00 Inner Boot Lid Glass Trim 20.00 (4pc) Tailgate Catch Surround 10.00 Door card inner strip trims 10.00 (pair) Door card rear belt covers 5.00 (pair) Boot Seal 10.00 First Aid Holder + Strap 10.00 Dash Blank 5.00 Door Pin/Lock Rods 5.00 each Inner Tailgate Scuff Guard 5.00 Door Pockets 20.00 (pair inc speaker grilles) Inner Door Handles 15.00 (pair - no mirror switch) Door Card S/B Fixings 5.00 (pair) Door Check Strap 5.00 HEATER Heater Box - Full 30.00 (3pc inc cables - move freely) Leg Heater Vents 10.00 (pair) Dashboard Heater Vents 20.00 (4pc - all fixings/clips in tact) Drivers Dash Vent Insert 5.00 Pass Dash Vent Insert 5.00 ROOF Sunroof Surround 5.00 Drivers Sun Visor 5.00 Pass Sun Visor inc Light 10.00 Roof Grab Handle 5.00 (Pass) Sunroof Motor Panel 10.00 SWITCH GEAR Rear Demister Switch 10.00 MFA Wiper Control Stalk 10.00 Indicator Control Stalk 10.00 Speedo Clocks (2.0 8v) 20.00 (140k approx) Sunroof Console 15.00 SOLD: Front Wings Black Door Cards Drivers Headlight Passengers Headlight Fog Lights Indicators 50mm Splitter Rear VR6 Badge Rear Corrado Badge Tail Light set Front Grill Chrome VW Badge Bonnet - Late spec bulge Doors Drivers Rear Quarter Carpet [black] A Pillar Trim B Pillar Trim Handbrake Plastic Cover Handbrake Handle Roof Mouldings Rear Bumper Pass Rear Quarter Dashboard Glovebox Steering Column Cowlings Passenger Undertray Drivers Undertray Gearshift Base + l/boot Gearknob (5spd) Tweeter Grills Fog Light Switch CONTINUED FURTHER DOWN THE PAGE... ------------------------------------------------------------------------------------------------------------------ Postage available on most items, collection from Cranfield, Beds for the larger, more fragile items. Regards, Stu Edited August 2, 2012 by StueyB Quote Share this post Link to post Share on other sites
daves16v 1 Posted February 19, 2012 Interested in the gear shifter assembly, don't need the cables. Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted February 19, 2012 What is the compatibility of panels between a late spec 8 valve and a 1993 VR6 please? Might be interested in wings, front bumper and bonnet but unsure if they are the same. Quote Share this post Link to post Share on other sites
Rustynuts 0 Posted February 19, 2012 Price on drivers side window motor and mechanism posted please Quote Share this post Link to post Share on other sites
shaunVR6 0 Posted February 19, 2012 Hi stuey are the frount ...i think they are called the frount knuckles the same as vr6 mate thanks shaun Quote Share this post Link to post Share on other sites
GusPW 0 Posted February 19, 2012 Hi is the dash centre console trim in good condition with no broken bits? If so how much? Quote Share this post Link to post Share on other sites
KIPVW 0 Posted February 19, 2012 What is the compatibility of panels between a late spec 8 valve and a 1993 VR6 please? Might be interested in wings, front bumper and bonnet but unsure if they are the same. Yep all the same, early cars pre 92 differ slightly Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 19, 2012 (edited) Continued... ELECTRIC / MECH Sunroof Panel & Motor 50.00 (once fixed) Rear Wiper Assembly 10.00 ABS ECU 25.00 Spoiler Motor Assembly 25.00 Spoiler Control Module 10.00 Window Control Module 15.00 Spoiler Switch 5.00 Boot Light 5.00 Boot Lifters 10.00 (pair) Boot Popper 5.00 C/L Vacuum Actuators 10.00 each (4 total, two doors, one boot, one fuel cap) Bonnet Cable Handle 5.00 ENGINE Radiator 40.00 Radiator Guard Left 10.00 Radiator Guard Right 10.00 Fan Setup 30.00 Washer Bottle Pump 5.00 Fuel Tank Cover 2.50 Wiring Heat Shield 2.50 Strut Top Caps 5.00 (pair) Master Cylinder + Bottle 25.00 Throttle Body Elbow 10.00 Brake Master Pipes 10.00 (2pc) Fuel Tank Straps 30.00 (3pc + bracket) Gear Selector Cables 15.00 (inc bracket) Airbox Air Guides 10.00 (pair) Scuttle Tray Cover 10.00 Throttle Cable 10.00 Bonnet Stay 5.00 (not rusty) Scuttle Tray Rubbers 10.00 (pair) Coolant Tank Side Cover 5.00 Foliage Cover 5.00 RUNNING GEAR Front 4 Stud Hubs 25.00 pair Front 256mm Brake Setup 40.00 (Calipers/Carriers/Discs/Pads - pair) Brake Servo 20.00 Handbrake Cables 20.00 (pair) Rear Brake Carriers 10.00 ------------------------------------------------------------- SOLD Full Stainless Exhaust Rear Brake Calipers Front Cross-member Rear Brake Bias Valve + Spring Head Bottom Engine - Scraped Gearbox Front Wiper Assembly Subframe/Wishbones/ARB Power Steering Rack Rear Stub Axles 3 x NEXEN N3000 - 205/40/17 17’’ BSA Multi-spoke Alloys Airbox Air Flow Meter Exhaust Hanger Set Rear Engine Bracket Drivers Win Reg & Motor C/L Pump ABS Pump -------------------------------------------------------------- Interested in the gear shifter assembly, don't need the cables. Can do mate and will remove cables. How does £30 sound..? Can get posted for a 5iver. ---------- Post added at 8:39 PM ---------- Previous post was at 8:35 PM ---------- What is the compatibility of panels between a late spec 8 valve and a 1993 VR6 please? Might be interested in wings, front bumper and bonnet but unsure if they are the same. As Kip says and as far as my experiences confirms, late spec cars are all the same with regards most panels. Just the slam panel which differs to accomodate radiators etc. Bonnet is in excellent condition, especially the under bonnet foam which is near perfect (never seen this before) Wings have a few marks but on the whole very solid and straight. Look very original as I don't think any of the car has had paint before. Bumper has some scuffs but again, very straight. Can provide pics of all of the above on request. Feel free to get in touch. Edited August 2, 2012 by StueyB Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted February 19, 2012 Interested in the front bumper, drivers front wing and bonnet - pics and prices please. Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 19, 2012 Price on drivers side window motor and mechanism posted please Window Motor - £20 Window Mech - £25 Happy to post before for £5 so a nice round £50 for both delivered to you. Have video's of both windows working smoothly. ---------- Post added at 8:44 PM ---------- Previous post was at 8:41 PM ---------- Hi stuey are the frount ...i think they are called the frount knuckles the same as vr6 mate thanks shaun Hi Shaun, Afraid I'm un sure of this, I'm sure someone will come along and confirm. I'd be surprised if they are different but will do some investigation to see if they are. £20 the pair of those + postage (likely to be £10 due to weight) Regards, Stu ---------- Post added at 8:48 PM ---------- Previous post was at 8:44 PM ---------- Hi is the dash centre console trim in good condition with no broken bits? If so how much? Gus, Dash centre console trim has been removed and is probably one of the best i've seen condition wise. It does have the very common missing lower right heater hole tab but that's it. No nasty cracks or scratches and even has the under stereo bar in one piece. Priced @ £50, similar to an almost identical one sold on here recently. Posted for £5 also as nice and light. Pics to follow. Stu ---------- Post added at 8:51 PM ---------- Previous post was at 8:48 PM ---------- Interested in the front bumper, drivers front wing and bonnet - pics and prices please. No probs, Bonnet - £50 Drivers wing - £30 Front bumper - £30 Happy to do the lot for £100 collected however. Can get pics tomorrow evening as I'm going over for a picture session. Regards, Stu Quote Share this post Link to post Share on other sites
KADVR6 0 Posted February 19, 2012 are the door handles available mate. Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 20, 2012 are the door handles available mate. Door handles will be Karl, still on the doors at the mo but both functional. Do you need keys..? Quote Share this post Link to post Share on other sites
KADVR6 0 Posted February 20, 2012 Door handles will be Karl, still on the doors at the mo but both functional. Do you need keys..? ok cool, and yeh will need at least one key so can you let me no how much posted for them please Stu. cheers mate karl Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 20, 2012 (edited) ok cool, and yeh will need at least one key so can you let me no how much posted for them please Stu. cheers mate karl Keys are no probs, however I do know the drivers handle has a different key to the rest of the car, is this a problem..? Basically be a key per handle. £50 delivered to you for the pair plus keys sound good..? Edited February 20, 2012 by StueyB Quote Share this post Link to post Share on other sites
4eyes2wheels 0 Posted February 20, 2012 Can I have first refusal on Bonnet - £50 Drivers wing - £30 Front bumper - £30 Pending photos and logistics for collection. Thanks Quote Share this post Link to post Share on other sites
Dollyman 10 Posted February 20, 2012 Hi Stu, Is the interior still available and if so, is a plain black or does it have a fleck or whatever? Cheers Jeff Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 20, 2012 (edited) Can I have first refusal on Bonnet - £50 Drivers wing - £30 Front bumper - £30 Pending photos and logistics for collection. Thanks Noted mate. Pics across late along with all others I've promised people. ---------- Post added at 1:43 PM ---------- Previous post was at 1:41 PM ---------- Hi Stu, Is the interior still available and if so, is a plain black or does it have a fleck or whatever? Cheers Jeff Hey Jeff, Most of interior is available. Seats wise the nice black cloth with the purple Flex. Not nasty holes or rips however drivers bolster as usual has collapsed so is on my hit list. Other than that very tidy interior, just needs a clean and hover which I will do in due course. What particularly are you interested in seats, doorcards, trim etc..? Edited February 20, 2012 by StueyB Quote Share this post Link to post Share on other sites
Dollyman 10 Posted February 20, 2012 Hi Stu, pm'd Cheers Jeff Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 21, 2012 Panels back up for sale due to distance. Door handles going tonight. First batch of items along shortly. Quote Share this post Link to post Share on other sites
deanjames 0 Posted February 22, 2012 Hi Stu Do you have the roof gutters, Rad Surround , and handbrake cover. Quote Share this post Link to post Share on other sites
Simon vr6 10 Posted February 22, 2012 Hi Stu do you have passenger side front fog light without any cracks?? Cheers Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 22, 2012 Hi Stu do you have passenger side front fog light without any cracks?? Cheers Afraid both fog lights are cracked. Quote Share this post Link to post Share on other sites
James. 9 Posted February 23, 2012 (edited) Looking for two (unbroken and as quick as possible) of these please (posted to lancashire): Edited February 24, 2012 by James. Quote Share this post Link to post Share on other sites
StueyB 0 Posted February 24, 2012 Hi James, Spoiler should be coming out later. Will drop you a line once I've assessed condition. Spoiler was working well so I would like to think they will both be fine. Regards, Stu Quote Share this post Link to post Share on other sites
Stonejag 10 Posted February 25, 2012 Hi Stu, How much for both rear quarter windows, rear numberplate plinth, rear wiper arm and one of the cubbyholes either side of the centre console at knee level? (I have one but not sure which side it is, so the other one ;)) Any chance you've got a moon roof? What colour are the rear badges? (if they're chrome I'll have the lot) Collection is no problem as I commute through Flitwick every day. If neither of the others can get to it I'll have the front bumper off you as well... Cheers, Nick Quote Share this post Link to post Share on other sites
