Southie
Candy White VR6
Had a 2.0 16V Corrado for about 3 years, then pick up the Candy white VR6 just over a year ago - so about time i started a members thread
Not long after purchase
When I got the car the water temp gauge didn’t work, luckily it was just that the needle had slipped off the back, Easy Fix, but then noticed it was running quite hot, had a poke around but couldn't see anything too bad, had a look at the water pump... Yuck! :gag:
So that set me off replacing most of the coolant system, just get the rad to do now, its little tired but works fine
Over the last 12 months its had...
OEM oil filter
OEM oil cooler
OEM water pump
Crack pipe
Thermostat and housing
Mocal 13 row oil cooler 90deg thermostatic plate
OEM alternator and belt
Spoon fed 70mm splitter and new fixings
SWG Scuttle cover
Full set of back samco’s with new spring clips
Refurbished 312’s & Goodridge hoses
Gear box mount
Toe eye cover
New battery and jacket
Sunroof switch
Sunroof motor
Alloys refurbished
Philips DAB stereo & speakers
New cobra CAT 1 alarm
Various trim pieces to tidy up the interior
US side markers
All red rear lights
OEM VSS
There are still lots of things on the list but it’s getting closer to where I want it to be :) Refurbishing the spoiler mech and finding a better canter console and leather handbrake cover are top at the moment
I don't have any recent pics but will try to get some over the weekend
Steve
Edited by Southie
Having seen lots of brand new cars in white recently and not liked them, I was pleasantly surprised at how good the four white Corrados looked at the CCGB Brooklands day meet recently. So a thumbs up from me - looks great!
Very nice. What temps were you running before and what are you running now?
Thanks,
Water was at 100-105 (Fan was coming on a lot) and oil 120-125, water is now at 85 ish and oil at 95, so a reduction of around 20 deg
Did a 486 miles this weekend on a trip to wales and back, The car could not have been better, didn't miss beat. Only managed to get 34mpg... the very wet but smooth twisty welsh roads might have had something to do with that :p
And a little helper...
Interior...
Steve
Little update, had a very annoying missfire over the last couple of months which turn out be be a wiring problem but its sorted now :cheers:
ended up getting a few new bit to eliminate causes of the misfire, They needed replacing anyway, and together with some freshed up engine plastics have smartened up the engine a little
Breu Coil pack
OEM red HT leads
OEM NKG Plugs
New painted engine plastics
OEM 3 Slat grill and silver badge
Lupo wipers and aero blades
New black scripted floor mats
Oh and a Nothelle 350mm wheel
Steve
another small update, fitted the Polyurethane engine mounts from Jays group buy
the front one went really easily but it was too good to last and i snapped the top bolt inside the rear mount :bonk: so got a new cheap one from GSF as the mounts were going to be changed anyway, and i finally got rid of the old cheap air filter that was fitted when i got the car and replaced it with a nice BMC CDA
Ohh and a new spare key :shades: which VW shorted out surprisingly quickly and at a reasonable price
Steve
Edited by Southie
how much did vw charge for a key then ??
Looks awesome!
I'd also like to know about the key. What did you need to order it? Does it have a chip in it?
Thanks All
Yes, its a chiped key with light (think they all have that tho don't they ?)
Just gave them my chassis number and it turned up within a week (cut obviously), it cost thirty something ponds with a small discount, not too bad IMO considering what VW charge for some Keys or Corrado items
Edited by Southie
That's excellent news! As the plastic tab that used to have my code on it seems to now be blank I didn't think I'd be able to get a spare. I know what I'll be ordering on Friday!
turbomagikz That looks very clean, gota love a white C :thumbleft:
No Updates, but a nice pic from today
Shame its only a phone pic
+1...very nice sunset picture and really likeing the Nothelle 350mm steering wheel. Think it suits the corrado interior in my opinion. Where did you find it ???
Thanks, it was just out side lower froyle on my way home
The wheel came from German eBay, i believe they are quite "rare" but can be had if you keep a look out
Car looking soooo much better with badged grill on too.!!! Keep it up- looking Tight!
hi sorry how did you get the key done? how much and what was the process.. i currently have 3 keays for boot ignition and passenger door.. wud prefer just the one lol
