daves16v 1 Posted July 31, 2012 I've got some Silicone hose that I need to shorten, anyone advise the best method to cut it cleanly? Obvious methods come to mind such as a Stanley knife or maybe a fine tooth hacksaw blade? Thanks for any help. Quote Share this post Link to post Share on other sites
Jim Bowen 1 Posted July 31, 2012 Samurai sword. Sent from my X10i using Tapatalk 2 Quote Share this post Link to post Share on other sites
lewvw 10 Posted July 31, 2012 A NEW stanley blade will be the best bet. Unless VR6 will lend you his laser but this may melt the hose. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted July 31, 2012 Hacksaw. Quote Share this post Link to post Share on other sites
MattPc 0 Posted July 31, 2012 If you can get a piece of hard plastic pipe or sheet, wrap this at the point of cutting, this will act as a guide giving you a smooth clean cut. A large retractable knife is best, as they're longer than the old Stanley blade. or speak to Dr evil he has sharks with lasers on their heads. Matt Quote Share this post Link to post Share on other sites
bristolbaron 11 Posted July 31, 2012 i went for a new stanley blade not in the knife. tighten a jubilee clip where you want to cut so you have an edge to go against. this will get you most of the way around, loosen and retighten so you can do the bit where it does up. Quote Share this post Link to post Share on other sites
Craig 0 Posted July 31, 2012 i went for a new stanley blade not in the knife. tighten a jubilee clip where you want to cut so you have an edge to go against. this will get you most of the way around, loosen and retighten so you can do the bit where it does up. Ditto, did this with a freshly sharpened house knife and worked a treat :) Quote Share this post Link to post Share on other sites
OllieVR6 0 Posted July 31, 2012 The first 3 responses in this thread are made of win! Quote Share this post Link to post Share on other sites
daves16v 1 Posted August 1, 2012 I should of mentioned the tube is 80mm dia with a 5mm internally braided wall, the usual Samco type stuff. Cheers for the gags and the suggestions. Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted August 1, 2012 Gaffer tape as a guide and a WD40 lubricated stanley blade. Works every time. Quote Share this post Link to post Share on other sites
VR6 0 Posted August 1, 2012 What lube though Kev? Bacon fat? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted August 1, 2012 What lube though Kev? Bacon fat? :lol: Quote Share this post Link to post Share on other sites
